Data SheetADG1211/ADG1212/ADG1213TYPICAL PERFORMANCE CHARACTERISTICS200250TVA = +25 ° CDD = +15V180VSS = –15VVDD = +13.5V160V200SS = –13.5VT))A = +125 ° C Ω 140 Ω 120150T100A = +85 ° CVDD = +15VVDD = +16.5V80V100SS = –15VVSS = –16.5VTA = +25 ° CON RESISTANCE (T60ON RESISTANCE (A = –40 ° C4050200 04778-008 0 04778-006 –18 –15 –12–9–6–30369121518–15–10–5051015SOURCE OR DRAIN VOLTAGE (V)SOURCE OR DRAIN VOLTAGE (V) Figure 4. On Resistance as a Function of VD (VS) for Dual Supply Figure 7. On Resistance as a Function of VD (VS) for Different Temperatures, Dual Supply 450600TA = +25 ° CVDD = +12V400VSS = 0V500TA = +125 ° C350TA = +85 ° C)) Ω V Ω 300DD = +5.5V400VSS = –5.5V250300200200ON RESISTANCE (150ON RESISTANCE (TA = –40 ° CTA = +25 ° C100100500 04778-004 0 04778-007 –5–4–3–2–1012345024681012SOURCE OR DRAIN VOLTAGE (V)SOURCE OR DRAIN VOLTAGE (V) Figure 5. On Resistance as a Function of VD (VS) for Dual Supply Figure 8. On Resistance as a Function of VD (VS) for Different Temperatures, Single Supply 4500.20TA = 25 ° CVDD = +15V400V0.15SS = –15VVDD = 12VVBIAS = +10V/–10VVDD = 10.8VV350SS = 0VVISS = 0V0.10D, IS (ON)) Ω 3000.05250IVD (OFF)DD = 13.2V0200VSS = 0VLEAKAGE (nA) –0.05I150S (OFF)ON RESISTANCE (–0.1010050–0.150 04778-005 –0.20 04778-012 024681012020406080100120SOURCE OR DRAIN VOLTAGE (V)TEMPERATURE ( ° C) Figure 6. On Resistance as a Function of VD (VS) for Single Supply Figure 9. Leakage Currents as a Function of Temperature, Dual Supply Rev. D | Page 9 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
