Datasheet ADG726, ADG732 (Analog Devices) - 5
Description16-/32-Channel, 4 Ω, +1.8 V to +5.5 V and ±2.5 V Analog Multiplexers
Pages / Page21 / 5 — Data Sheet. ADG726/ADG732. +3 V SINGLE SUPPLY. Table 2. ADG726/. ADG732. …
RevisionC
File Format / SizePDF / 350 Kb
Data Sheet. ADG726/ADG732. +3 V SINGLE SUPPLY. Table 2. ADG726/. ADG732. −40°C to. Parameter Symbol. +25°C. +85°C. +125°C. Unit Test
Data Sheet ADG726/ADG732 +3 V SINGLE SUPPLY Table 2 ADG726/ ADG732 −40°C to Parameter Symbol +25°C +85°C +125°C Unit Test
link to page 17 link to page 17 link to page 17 link to page 17 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 18 link to page 19 link to page 17 link to page 17 link to page 17 link to page 6
VDD = 3 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 2. ADG726/ ADG732 ADG732 −40°C to −40°C to Parameter Symbol +25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to V VDD On Resistance RON 7 Ω typ VS = 0 V to VDD, IDS = 10 mA, see Figure 20 11 12 13 Ω max On Resistance Match Between ΔRON 0.35 Ω typ VS = 0 V to VDD, IDS = 10 mA Channels 1 1 Ω max On Resistance Flatness RFLAT (ON) 3 Ω typ VS = 0 V to VDD, IDS = 10 mA LEAKAGE CURRENTS VDD = 3.3 V Source Off Leakage IS (Off) ±0.01 nA typ VS = 3 V/1 V, VD = 1 V/3 V, see Figure 21 ±0.25 ±1 ±2 nA max Drain Off Leakage ID (Off) ±0.05 nA typ VS = 1 V/3 V, VD = 3 V/1 V, see Figure 24 ADG726 ±0.5 ±2.5 nA max ADG732 ±1 ±5 ±10 nA max Channel On Leakage ID, IS (On) ±0.05 nA typ VS = VD = 1 V or 3 V, see Figure 25 ADG726 ±0.5 ±2.5 nA max ADG732 ±1 ±5 ±10 nA max DIGITAL INPUTS Input High Voltage VINH 2.0 2.0 V min Input Low Voltage VINL 0.7 0.7 V max Input Current Low or High IINL or IINH 0.005 μA typ VIN = VINL or VINH ±0.5 ±0.5 μA max Digital Input Capacitance CIN 5 pF typ DYNAMIC CHARACTERISTICS1 Transition Time tTRANSITION 34 ns typ RL = 300 Ω, CL = 35 pF, see Figure 27 52 62 69 ns max VS1 = 2 V/0 V, VS32 = 0 V/2 V Break-Before-Make Time Delay tD 26 ns typ RL = 300 Ω, CL = 35 pF; VS = 2 V, see Figure 28 1 1 ns min On Time (CS, WR) tON (WR, CS) 29 ns typ RL = 300 Ω, CL = 35 pF; VS = 2 V, see Figure 29 43 52 60 ns max Off Time (CS, WR) tOFF (WR, CS) 26 ns typ RL = 300 Ω, CL = 35 pF; VS = 2 V, see Figure 29 38 42 55.5 ns max On Time (EN) tON (EN) 33 ns typ RL = 300 Ω, CL = 35 pF; VS = 2 V, see Figure 30 48 55 63.5 ns max Off Time (EN) tOFF (EN) 19 ns typ RL = 300 Ω, CL = 35 pF; VS = 2 V, see Figure 30 25 28 28 ns max Charge Injection QINJ 1 pC typ VS = 1.5 V, RS = 0 Ω, CL = 1 nF, see Figure 31 Off Isolation ISO −72 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 22 Channel-to-Channel Crosstalk CTK −72 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz, see Figure 23 −3 dB Bandwidth BW RL = 50 Ω, CL = 5 pF, see Figure 26 ADG726 34 MHz typ ADG732 18 MHz typ Rev. C | Page 5 of 21 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS +5 V SINGLE SUPPLY +3 V SINGLE SUPPLY ±2.5 V DUAL SUPPLY TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTION 48-LEAD TQFP 48-LEAD LFCSP Truth Tables TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
