Datasheet ADG604 (Analog Devices)
Description | 1 pC Charge Injection, 100 pA Leakage CMOS 5 V/5 V/3 V 4-Channel Multiplexer |
Pages / Page | 11 / 1 — 1 pC Charge Injection, 100 pA Leakage. CMOS. 5 V/5 V/3 V 4-Channel … |
Revision | A |
File Format / Size | PDF / 236 Kb |
1 pC Charge Injection, 100 pA Leakage. CMOS. 5 V/5 V/3 V 4-Channel Multiplexer. ADG604. FEATURES. FUNCTIONAL BLOCK DIAGRAM
a
1 pC Charge Injection, 100 pA Leakage CMOS 5 V/5 V/3 V 4-Channel Multiplexer ADG604 FEATURES FUNCTIONAL BLOCK DIAGRAM 1 pC Charge Injection (Over the Full Signal Range) 2.7 V to 5.5 V Dual Supply ADG604 2.7 V to 5.5 V Single Supply S1 4 Temperature Range: –40 C to +125 C 100 pA Max @ 25 C Leakage Currents S2 5 6 85 D Typ On Resistance S3 11 Rail-to-Rail Operation Fast Switching Times S4 10 Typical Power Consumption (<0.1 W) TTL/CMOS Compatible Inputs 1 OF 4 DECODER 14-Lead TSSOP Package 1 14 2 APPLICATIONS A0 A1 EN Automatic Test Equipment Data Acquisition Systems Battery-Powered Instruments Communication Systems Sample and Hold Systems Remote-Powered Equipment Audio and Video Signal Routing Relay Replacement Avionics GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG604 is a CMOS analog multiplexer, comprising four 1. Ultralow Charge Injection (Q INJ: ± 1.5 pC Typ over the Full single channels. It operates from a dual supply of ± 2.7 V to Signal Range) ±5.5 V, or from a single supply of 2.7 V to 5.5 V. 2. Leakage Current <0.5 nA max @ 85°C The ADG604 switches one of four inputs to a common output, 3. Dual ± 2.7 V to ± 5.5 V or Single 2.7 V to 5.5 V Supply D, as determined by the 3-bit binary address lines, A0, A1, and EN. A Logic “0” on the EN pin disables the device. 4. Fully Specified to 125°C The ADG604 offers ultralow charge injection of ±1.5 pC over the 5. Small 14-Lead TSSOP Package entire signal range and leakage currents of 10 pA typical at 25°C. It offers on resistance of 85 Ω typ, which is matched to within 2 Ω between channels. The ADG604 also has low power dissipation yet gives high switching speeds. The ADG604 is available in a 14-lead TSSOP package. REV. A
Document Feedback
Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its
use, nor for any infringements of patents or other rights of third parties that
Tel: 781.329.4700 ©2018 Analog Devices, Inc. All rights reserved.
may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices.
Technical Support www.analog.com
