Datasheet ADG604 (Analog Devices) - 5
Description1 pC Charge Injection, 100 pA Leakage CMOS 5 V/5 V/3 V 4-Channel Multiplexer
Pages / Page11 / 5 — ADG604. ABSOLUTE MAXIMUM RATINGS1. PIN CONFIGURATION. Table I. Truth …
RevisionA
File Format / SizePDF / 236 Kb
ADG604. ABSOLUTE MAXIMUM RATINGS1. PIN CONFIGURATION. Table I. Truth Table. ON Switch. 14 A1. 13 GND. VSS 3. 12 VDD. TOP VIEW. 11 S3
ADG604 ABSOLUTE MAXIMUM RATINGS1 PIN CONFIGURATION Table I Truth Table ON Switch 14 A1 13 GND VSS 3 12 VDD TOP VIEW 11 S3
Junction Temperature . 150°C (TA = 25°C unless otherwise noted) TSSOP Package V ␪ DD to VSS . 13 V JA Thermal Impedance . 150°C/W V ␪ DD to GND . –0.3 V to +6.5 V JC Thermal Impedance . 27°C/W V Lead Temperature, Soldering (10 seconds) . 300°C SS to GND . +0.3 V to –6.5 V Analog Inputs2 . V IR Reflow, Peak Temperature . 220°C SS –0.3 V to VDD + 0.3 V Digital Inputs2 . –0.3 V to VDD + 0.3 V or . 30 mA, Whichever Occurs First NOTES 1Stresses above those listed under Absolute Maximum Ratings may cause perma- Peak Current, S or D . 20 mA nent damage to the device. This is a stress rating only; functional operation of the (Pulsed at 1 ms, 10% Duty Cycle Max) device at these or any other conditions above those listed in the operational Continuous Current, S or D . 10 mA sections of this specification is not implied. Exposure to absolute maximum rating Operating Temperature Range conditions for extended periods may affect device reliability. Only one absolute maximum rating may be applied at any one time. (Y Version) . –40°C to +125°C 2Overvoltages at EN, A0, A1, S, or D will be clamped by internal diodes. Current Storage Temperature Range . –65°C to +150°C should be limited to the maximum ratings given.
PIN CONFIGURATION Table I. Truth Table A1 A0 EN ON Switch A0 1 14 A1
X X 0 None
EN 2 13 GND ADG604
0 0 1 1
VSS 3 12 VDD
0 1 1 2
TOP VIEW S1 4 11 S3 (Not To Scale)
1 0 1 3
S2 5 10 S4
1 1 1 4
D 6 9 NC NC 7 8 NC NC = NO CONNECT CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although
WARNING!
the ADG604 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high-energy electrostatic discharges. Therefore, proper ESD precautions are
ESD SENSITIVE DEVICE
recommended to avoid performance degradation or loss of functionality. REV. A –5–
