Datasheet ADG613-EP (Analog Devices) - 3
Description1 pC Charge Injection, 100 pA Leakage, CMOS, ±5 V/ +5 V/ +3 V, Quad SPST Switches
Pages / Page12 / 3 — Enhanced Product. ADG613-EP. SPECIFICATIONS. DUAL-SUPPLY OPERATION. Table …
File Format / SizePDF / 258 Kb
Enhanced Product. ADG613-EP. SPECIFICATIONS. DUAL-SUPPLY OPERATION. Table 1. Parameter. 25°C. −55°C to +125°C. Unit
Enhanced Product ADG613-EP SPECIFICATIONS DUAL-SUPPLY OPERATION Table 1 Parameter 25°C −55°C to +125°C Unit
link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 11 link to page 11 link to page 11
VDD = 5 V ± 10%, VSS = −5 V ± 10%, GND = 0 V, unless otherwise noted. VS is the source voltage. VD is the drain voltage.
Table 1. Parameter 25°C −55°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VSS to VDD V On Resistance, RON 85 Ω typ VS = ±3 V, IS = −1 mA; see Figure 14 115 160 Ω max VS = ±3 V, IS = −1 mA; see Figure 14 On-Resistance Match Between Channels, ΔRON 2 Ω typ VS = ±3 V, IS = −1 mA 4 6.5 Ω max VS = ±3 V, IS = −1 mA On-Resistance Flatness, RFLAT(ON) 25 Ω typ VS = ±3 V, IS = −1 mA 40 60 Ω max VS = ±3 V, IS = −1 mA LEAKAGE CURRENTS VDD = +5.5 V, VSS = −5.5 V Source Off Leakage, IS(OFF) ±0.01 nA typ VD = ±4.5 V, VS = +4.5 V; see Figure 15 ±0.1 ±2 nA max VD = ±4.5 V, VS = +4.5 V; see Figure 15 Drain Off Leakage, ID(OFF) ±0.01 nA typ VD = ±4.5 V, VS = +4.5 V; see Figure 15 ±0.1 ±2 nA max VD = ±4.5 V, VS = +4.5 V; see Figure 15 Channel On Leakage, ID(ON), IS(ON) ±0.01 nA typ VD = VS = ±4.5 V; see Figure 16 ±0.1 ±6 nA max VD = VS = ±4.5 V; see Figure 16 DIGITAL INPUTS Input High Voltage, VINH 2.4 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.005 μA typ VIN = VINL or VINH ±0.1 μA max VIN = VINL or VINH Digital Input Capacitance, CIN 2 pF typ DYNAMIC CHARACTERISTICS1 Delay from Digital Control Input and Output 45 ns typ RL = 300 Ω, CL = 35 pF, VS = 3.0 V; see Figure 17 Switching On, tON 65 90 ns max RL = 300 Ω, CL = 35 pF, VS = 3.0 V; see Figure 17 Delay from Digital Control Input and Output 25 ns typ RL = 300 Ω, CL = 35 pF, VS = 3.0 V; see Figure 17 Switching Off, tOFF 40 50 ns max RL = 300 Ω, CL = 35 pF, VS = 3.0 V; see Figure 17 Break-Before-Make Time Delay, tBBM 15 ns typ RL = 300 Ω, CL = 35 pF, VS1 = VS2 = 3.0 V; see Figure 18 10 ns min RL = 300 Ω, CL = 35 pF, VS1 = VS2 = 3.0 V; see Figure 18 Charge Injection −0.5 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF; see Figure 19 Off Isolation −65 dB typ RL = 50 Ω, CL = 5 pF, f = 10 MHz; see Figure 20 Channel to Channel Crosstalk −90 dB typ RL = 50 Ω, CL = 5 pF, f = 10 MHz; see Figure 21 −3 dB Bandwidth 680 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 22 Off Switch Source Capacitance, CS(OFF) 5 pF typ f = 1 MHz Off Switch Drain Capacitance, CD(OFF) 5 pF typ f = 1 MHz On Switch Capacitance, CD(ON), CS(ON) 5 pF typ f = 1 MHz POWER REQUIREMENTS VDD = +5.5 V, VSS = −5.5 V Positive Supply Current, IDD 0.001 μA typ Digital inputs = 0 V or 5.5 V 1.0 μA max Digital inputs = 0 V or 5.5 V Negative Supply Current, ISS 0.001 μA typ Digital inputs = 0 V or 5.5 V 1.0 μA max Digital inputs = 0 V or 5.5 V VDD/VSS ±2.7 V min ±5.5 V max Power Consumption 11 nW typ 11 µW max 1 Guaranteed by design; not subject to production test. Rev. A | Page 3 of 12 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL-SUPPLY OPERATION SINGLE-SUPPLY OPERATION ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
