Datasheet ADG636 (Analog Devices) - 9
Description1 pC Charge Injection, 100 pA Leakage, CMOS, ±5 V/+5 V/+3 V Dual SPDT Switch
Pages / Page16 / 9 — ADG636. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter Rating. ESD CAUTION
File Format / SizePDF / 505 Kb
ADG636 ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
link to page 9
Table 4.
Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress
Parameter Rating
rating only; functional operation of the device at these or any VDD to VSS 13 V other conditions above those indicated in the operational VDD to GND −0.3 V to +6.5 V section of this specification is not implied. Exposure to absolute VSS to GND +0.3 V to −6.5 V maximum rating conditions for extended periods may affect Analog Inputs1 VSS − 0.3 V to VDD + 0.3 V device reliability. Digital Inputs1 −0.3 V to VDD + 0.3 V or 30 mA, whichever Only one absolute maximum rating may be applied at any one occurs first time. Peak Current, S or D (Pulsed at 1 ms, 20 mA 10% Duty Cycle Maximum)
ESD CAUTION
Continuous Current, S or D 10 mA Operating Temperature Range −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C TSSOP Package θJA Thermal Impedance 150°C/W θJC Thermal Impedance 27°C/W Lead Soldering Lead Temperature, Soldering (10 sec) 300°C IR Reflow, Peak Temperature (<20 sec) 220°C Pb-Free Soldering Reflow, Peak Temperature 260(+0/−5)°C Time at Peak Temperature 20 sec to 40 sec 1 Overvoltages at EN, A0, A1, S, or D are clamped by internal diodes. Current should be limited to the maximum ratings given. Rev. B | Page 9 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
