Datasheet ADG601, ADG602 (Analog Devices) - 8 Manufacturer Analog Devices Description 2 Ω, CMOS, ±5 V/+5 V SPST Switches Pages / Page 12 / 8 — ADG601/ADG602. Data Sheet. 500. TA = 25°C. 450. –10. 400. –20. 350. ) B. … Revision D File Format / Size PDF / 206 Kb Document Language English
ADG601/ADG602. Data Sheet. 500. TA = 25°C. 450. –10. 400. –20. 350. ) B. N (. 300. VDD = +5V. –30. VSS = –5V. IO T. 250. A –40. 200. –50. F IS. HARG. 150. DD = +5V
Model Line for this Datasheet Text Version of Document ADG601/ADG602 Data Sheet 500 0 TA = 25°C 450 –10 400 C) –20 p 350 ) B N ( (d IO 300 VDD = +5V –30 N CT VSS = –5V IO T JE 250 A –40 N L I O E 200 –50 F IS V HARG 150 DD = +5V OF C VSS = 0V –60 100 VDD = +5V 50 –70 VSS = –5V TA = 25°C 0 0–80 2–5 –4 –3 –2 –1 0 1 2 3 4 5 -010.2 1 10 100 01 9-V 19S (V) 61 26FREQUENCY (MHz) 0 02 Figure 11. Charge Injection vs. Source Voltage Figure 13. Off Isolation vs. Frequency180 0 160 –2 140 VDD = +5V VSS = 0V ) 120 B V –4 DD = +5V d ( ) t V ON SS = –5V E ns 100 S ( ON –6 P S TIME 80 E R 60 t –8 ON OFF 40 VDD = +5V –10 VDD = +5V V 20 DD = +5V VSS = –5V VSS = –5V VSS = 0V TA = 25°C 0 –12 1 3–40 –20 0 20 40 60 80 -010.2 1 10 100 400 -01 19 19TEMPERATURE (°C) FREQUENCY (MHz) 26 026 0 Figure 12. tON/tOFF Times vs. Temperature Figure 14. On Response vs. Frequency Rev. D | Page 8 of 12 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
