Datasheet ADG601, ADG602 (Analog Devices) - 9
Description2 Ω, CMOS, ±5 V/+5 V SPST Switches
Pages / Page12 / 9 — Data Sheet. ADG601/ADG602. TERMINOLOGY VDD. VINL. VSS. VINH. IDD. IINL …
RevisionD
File Format / SizePDF / 206 Kb
Data Sheet. ADG601/ADG602. TERMINOLOGY VDD. VINL. VSS. VINH. IDD. IINL (IINH). ISS. CS (Off). GND. CD (Off). CD, CS (On). CIN. tON. VD, VS. tOFF. RON
Data Sheet ADG601/ADG602 TERMINOLOGY VDD VINL VSS VINH IDD IINL (IINH) ISS CS (Off) GND CD (Off) CD, CS (On) CIN tON VD, VS tOFF RON
Most positive power supply potential. Maximum input voltage for Logic 0.
VSS VINH
Most negative power supply potential. Minimum input voltage for Logic 1.
IDD IINL (IINH)
Positive supply current. Input current of the digital input.
ISS CS (Off)
Negative supply current. Off switch source capacitance. Measured with reference to ground.
GND CD (Off)
Ground (0 V) reference. Off switch drain capacitance. Measured with reference to ground.
S CD, CS (On)
Source terminal. Can be an input or an output. On switch capacitance. Measured with reference to ground.
D CIN
Drain terminal. Can be an input or an output. Digital input capacitance.
IN tON
Logic control input. Delay between applying the digital control input and the output switching on.
VD, VS
Analog voltage on Terminal D and Terminal S.
tOFF
RON
switching off. Ohmic resistance between Terminal D and Terminal S.
Charge Injection RFLAT (ON)
A measure of the glitch impulse transferred from the digital Flatness is defined as the difference between the maximum and input to the analog output during switching. minimum values of on resistance as measured over the specified analog signal range.
Off Isolation
A measure of unwanted signal coupling through an off switch.
IS (Off)
Source leakage current with the switch off.
On Response
Frequency response of the on switch.
ID (Off)
Drain leakage current with the switch off.
Insertion Loss
Loss due to the on resistance of the switch.
ID, IS (On)
Channel leakage current with the switch on. Rev. D | Page 9 of 12 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
