Datasheet ADG786, ADG788 (Analog Devices) - 7
Description2.5 , 1.8 V to 5.5 V, 2.5 V Triple/Quad SPDT Switches in Chip Scale Packages
Pages / Page11 / 7 — Typical Performance Characteristics– ADG786/ADG788. TA = 25. VDD = 5V. …
RevisionC
File Format / SizePDF / 368 Kb
Typical Performance Characteristics– ADG786/ADG788. TA = 25. VDD = 5V. VSS = 0V. DD = 2.7V. VDD = 3.3V. VDD = +2.5V. VDD = 4.5V
Typical Performance Characteristics– ADG786/ADG788 TA = 25 VDD = 5V VSS = 0V DD = 2.7V VDD = 3.3V VDD = +2.5V VDD = 4.5V
Typical Performance Characteristics– ADG786/ADG788 8 8 8 TA = 25 C TA = 25 C VDD = 5V 7 VSS = 0V 7 7 VSS = 0V 6 V DD = 2.7V 6 6 5 VDD = 3.3V 5 5 VDD = +2.5V 4 VDD = 4.5V 4 V 4 SS = –2.5V +25 C +85 C 3 3 3 ON RESISTANCE – 2 ON RESISTANCE – 2 ON RESISTANCE – 2 VDD = 5.5V –40 C 1 1 1 0 0 0 0 1 2 3 4 5 –3 –2 –1 0 1 2 3 0 1 2 3 4 5 VD, VS, DRAIN OR SOURCE VOLTAGE – V VD, VS, DRAIN OR SOURCE VOLTAGE – V VD, VS, DRAIN OR SOURCE VOLTAGE – V
TPC 1. On Resistance as a Function TPC 2. On Resistance as a Function TPC 3. On Resistance as a Function of V of V of V D(VS) for Single Supply D(VS) for Dual Supply D(VS) for Different Temperatures, Single Supply
8 8 0.10 V V V DD = 3V DD = +2.5V DD = 5V 7 V V V SS = 0V 7 SS = –2.5V SS = GND TA = 25 C 0.05 6 6 IS, ID (ON), VD = VS +85 C 5 5 – nA 0 4 4 +25 C –40 C +85 C 3 –0.05 3 CURRENT IS (OFF) ON RESISTANCE – ON RESISTANCE – 2 +25 C 2 –40 C –0.10 1 1 0 0 –0.15 0 0.5 1.0 1.5 2.0 2.5 3.0 –3 –2 –1 0 1 2 3 0 1 2 3 4 5 VD, VS, DRAIN OR SOURCE VOLTAGE – V VD, VS, DRAIN OR SOURCE VOLTAGE – V VS, (VD = VDD –VS) – V
TPC 4. On Resistance as a Function TPC 5. On Resistance as a Function TPC 6. Leakage Currents as a of V Function of V D(VS) for Different Temperatures, of VD(VS) for Different Temperatures, D(VS) Single Supply Dual Supply
0.10 0.15 0.25 VDD = 3V VDD = +2.5V VDD = +2.5V VDD = 5V 0.08 VSS = GND VSS = –2.5V VSS = –2.5V VSS = GND 0.20 T 0.10 A = 25 C V V 0.06 TA = 25 C D = +2.25V/–1.25V D = 4.5V/1.0V VS = –1.25V/+2.25V VS = 1.0V/4.5V 0.04 0.15 0.05 – nA 0.02 IS, ID (ON), VD = VS – nA IS, ID (ON), VD = VS – nA 0.10 0 0 I –0.02 0.05 S, ID (ON) CURRENT CURRENT –0.05 CURRENT –0.04 0 –0.06 I I S (OFF) S (OFF) –0.10 IS (OFF) –0.05 –0.08 –0.10 –0.15 –0.10 0 0.5 1.0 1.5 2.0 2.5 3.0 –3 –2 –1 0 1 2 3 5 20 35 50 65 80 VS, (VD = VDD –VS) – V VS, (VD = VDD –VS) – V TEMPERATURE – C
TPC 7. Leakage Currents as a TPC 8. Leakage Currents as a TPC 9. Leakage Currents as a Function of VD(VS) Function of VD(VS) Function of Temperature REV. $ –7–
