Datasheet ADG786, ADG788 (Analog Devices) - 8
Description2.5 , 1.8 V to 5.5 V, 2.5 V Triple/Quad SPDT Switches in Chip Scale Packages
Pages / Page11 / 8 — ADG786/ADG788. 0.25. VDD = 3V. VSS = GND. 0.20. VD = 2.7V/1V. ON, VDD = …
RevisionC
File Format / SizePDF / 368 Kb
ADG786/ADG788. 0.25. VDD = 3V. VSS = GND. 0.20. VD = 2.7V/1V. ON, VDD = 3V. DD = 5V. VS = 1V/2.7V. 0.15. A = 25. – –6. – nA. 0.10. tON, VDD = 5V
ADG786/ADG788 0.25 VDD = 3V VSS = GND 0.20 VD = 2.7V/1V ON, VDD = 3V DD = 5V VS = 1V/2.7V 0.15 A = 25 – –6 – nA 0.10 tON, VDD = 5V
ADG786/ADG788 0.25 40 0 VDD = 3V VSS = GND VSS = GND 0.20 35 –2 VD = 2.7V/1V t V ON, VDD = 3V DD = 5V VS = 1V/2.7V 30 –4 T 0.15 A = 25 C dB 25 – –6 – nA 0.10 tON, VDD = 5V – ns 20 –8 0.05 TIME IS, ID (ON) 15 RESPONSE –10 CURRENT 0 t ON 10 OFF, VDD = 3V –12 –0.05 tOFF, VDD = 5V 5 –14 IS (OFF) –0.10 0 –16 5 20 35 50 65 80 –20 0 20 40 60 80 10k 100k 1M 10M 100M TEMPERATURE – C TEMPERATURE – C FREQUENCY – HZ
TPC 10. Leakage Currents as a TPC 11. tON / tOFF Times vs. TPC 12. On Response vs. Frequency Function of Temperature Temperature
10m TA = 25 C 1m VDD = 5V VSS = GND 100 – A VDD = +2.5V 10 V SS = –2.5V CURRENT 1 VSS = 3V 100n VDD = GND 10n 0.1 1 10 100 1000 10000 FREQUENCY – kHz
TPC 13. Input Current, IDD vs. TPC 14. Off Isolation vs. Frequency TPC 15. Crosstalk vs. Frequency Switching Frequency
30 T V A = 25 C DD = +2.5V VSS = –2.5V 20 VDD = 3V VSS = GND – pC 10 INJQ 0 VDD = 5V VSS = GND –10–3 –2 –1 0 1 2 3 4 5 VOLTAGE – V
TPC 16. Charge Injection vs. Source Voltage –8– REV. $
