Datasheet ADG733, ADG734 (Analog Devices) - 8
DescriptionCMOS, 2.5 Ω Low Voltage, Triple/Quad SPDT Switches
Pages / Page12 / 8 — ADG733/ADG734. 0.25. VDD = 3V. VSS = GND. SS = GND. 0.20. D = 2.7V/1V. DD …
File Format / SizePDF / 209 Kb
ADG733/ADG734. 0.25. VDD = 3V. VSS = GND. SS = GND. 0.20. D = 2.7V/1V. DD = 5V. ON, VDD = 3V. S = 1V/2.7V. A = 25. 0.15. dB –. 0.10. tON, VDD = 5V
ADG733/ADG734 0.25 VDD = 3V VSS = GND SS = GND 0.20 D = 2.7V/1V DD = 5V ON, VDD = 3V S = 1V/2.7V A = 25 0.15 dB – 0.10 tON, VDD = 5V
ADG733/ADG734 0 0.25 40 VDD = 3V VSS = GND V –2 SS = GND 0.20 35 V V D = 2.7V/1V t DD = 5V ON, VDD = 3V V –4 T S = 1V/2.7V 30 A = 25 C 0.15 dB – –6 25 0.10 tON, VDD = 5V –8 20 0.05 TIME – ns –10 I 15 RESPONSE CURRENT – nA S, ID (ON) ON 0 t –12 10 OFF, VDD = 3V –0.05 t –14 OFF, VDD = 5V 5 IS (OFF) –0.10 0 –16 5 20 35 50 65 80 –20 0 20 40 60 80 10k 100k 1M 10M 100M FREQUENCY – HZ TEMPERATURE – C TEMPERATURE – C
TPC 10. Leakage Currents as a TPC 11. t TPC 12. On Response vs. Frequency ON /tOFF Times vs. Function of Temperature Temperature
10m 0 0 V T V DD = 5V A = 25 C DD = 5V T T A = 25 C A = 25 C 1m –20 –20 VDD = 5V VSS = GND 100 –40 –40 VDD = +2.5V 10 V –60 SS = –2.5V –60 CURRENT – A 1 –80 –80 ATTENUATION – dB ATTENUATION – dB VSS = 3V 100n V –100 DD = GND –100 10n –120 –120 0.1 1 10 100 1000 10000 30k 100k 1M 10M 100M 30k 100k 1M 10M 100M FREQUENCY – kHz FREQUENCY – kHz FREQUENCY – kHz
TPC 13. Input Current, I TPC 15. Crosstalk vs. Frequency DD vs. TPC 14. Off Isolation vs. Frequency Switching Frequency
30 T V A = 25 C DD = +2.5V VSS = –2.5V 20 VDD = 3V VSS = GND – pC 10 INJQ 0 VDD = 5V VSS = GND –10–3 –2 –1 0 1 2 3 4 5 VOLTAGE – V
TPC 16. Charge Injection vs. Source Voltage –8– REV. B Document Outline Features Applications General Description Functional Block Diagrams Product Highlights Specifications Absolute Maximum Ratings Pin Configurations Terminology Typical Performance Characteristics Test Circuits Outline Dimensions Ordering Guide Revision History
