Datasheet ADG733, ADG734 (Analog Devices) - 7
DescriptionCMOS, 2.5 Ω Low Voltage, Triple/Quad SPDT Switches
Pages / Page12 / 7 — Typical Performance Characteristics–ADG733/ADG734. A = 25. DD = 5V. SS = …
File Format / SizePDF / 209 Kb
Typical Performance Characteristics–ADG733/ADG734. A = 25. DD = 5V. SS = 0V. DD = 2.7V. DD = 3.3V. VDD = +2.5V. VDD = 4.5V. SS = –2.5V
Typical Performance Characteristics–ADG733/ADG734 A = 25 DD = 5V SS = 0V DD = 2.7V DD = 3.3V VDD = +2.5V VDD = 4.5V SS = –2.5V
Typical Performance Characteristics–ADG733/ADG734 8 8 8 T T V A = 25 C A = 25 C DD = 5V 7 V 7 7 V SS = 0V SS = 0V 6 V 6 6 DD = 2.7V 5 V 5 5 DD = 3.3V VDD = +2.5V 4 VDD = 4.5V 4 V 4 SS = –2.5V +25 C +85 C 3 3 3 ON RESISTANCE – ON RESISTANCE – ON RESISTANCE – 2 2 2 VDD = 5.5V –40 C 1 1 1 0 0 0 0 1 2 3 4 5 –3 –2 –1 0 1 2 3 0 1 2 3 4 5 V V V D, VS, DRAIN OR SOURCE VOLTAGE – V D, VS, DRAIN OR SOURCE VOLTAGE – V D, OR VS DRAIN OR SOURCE VOLTAGE – V
TPC 1. On Resistance as a Function of TPC 2. On Resistance as a Function of TPC 3. On Resistance as a Function of V V D (VS) for Single Supply VD (VS) for Dual Supply D (VS) for Different Temperatures, Single Supply
8 8 0.1 V VDD = +2.5V V DD = 3V DD = 5V 7 V 7 VSS = –2.5V V SS = 0V SS = GND TA = 25 C 0.05 6 6 IS, ID (ON) +85 C 5 5 0 4 4 +25 C –40 C +85 C 3 3 –0.05 CURRENT – nA IS (OFF) ON RESISTANCE – ON RESISTANCE – 2 +25 C 2 –40 C –0.1 1 1 0 0 –0.15 0 0.5 1.0 1.5 2.0 2.5 3.0 –3 –2 –1 0 1 2 3 0 1 2 3 4 5 VD OR VS – DRAIN OR SOURCE VOLTAGE – V VD, VS, DRAIN OR SOURCE VOLTAGE – V VS, (VD = VDD – VS) – V
TPC 4. On Resistance as a Function of TPC 5. On Resistance as a Function of TPC 6. Leakage Currents as a VD (VS) for Different Temperatures, VD (VS) for Different Temperatures, Function of VD (VS) Single Supply Dual Supply
0.10 0.15 0.25 V V V V DD = 3V DD = +2.5V DD = +2.5V DD = 5V 0.08 V V V V SS = GND SS = –2.5V SS = –2.5V SS = GND 0.20 T 0.10 T V V A = 25 C D = +2.25V/–1.25V D = 4.5V/1.0V 0.06 A = 25 C VS = –1.25V/+2.25V VS = 1.0V/4.5V 0.04 0.15 0.05 0.02 IS, ID (ON) IS, ID (ON), VD = VS 0.10 0 0 I 0.05 S, ID (ON) –0.02 CURRENT – nA CURRENT – nA –0.05 CURRENT – nA –0.04 0 I –0.06 I S (OFF) S (OFF) I –0.10 S (OFF) –0.05 –0.08 –0.10 –0.15 –0.10 0 0.5 1.0 1.5 2.0 2.5 3.0 –3 –2 –1 0 1 2 3 5 20 35 50 65 80 V V TEMPERATURE – C S, (VD = VDD – VS) – V S, (VD = VDD –VS) – V
TPC 7. Leakage Currents as a TPC 8. Leakage Currents as a TPC 9. Leakage Currents as a Function of VD (VS) Function of V Function of Temperature D (VS) REV. B –7– Document Outline Features Applications General Description Functional Block Diagrams Product Highlights Specifications Absolute Maximum Ratings Pin Configurations Terminology Typical Performance Characteristics Test Circuits Outline Dimensions Ordering Guide Revision History
