Datasheet ADG714, ADG715 (Analog Devices) - 4
DescriptionCMOS, Low Voltage Serially Controlled, Octal SPST Switches
Pages / Page21 / 4 — ADG714/. ADG715. Data Sheet. Parameter. +25°C. −40°C to +85°C. Unit. Test …
RevisionE
File Format / SizePDF / 368 Kb
ADG714/. ADG715. Data Sheet. Parameter. +25°C. −40°C to +85°C. Unit. Test Conditions/Comments. 3 V SINGLE SUPPLY. Table 2. Parameter
ADG714/ ADG715 Data Sheet Parameter +25°C −40°C to +85°C Unit Test Conditions/Comments 3 V SINGLE SUPPLY Table 2 Parameter
Off Time, tOFF ADG714 8 ns typ VS = 3 V, RL = 300 Ω, CL = 35 pF 15 ns max ADG715 85 ns typ VS = 3 V, RL = 300 Ω, CL = 35 pF 130 ns max Break-Before-Make Time Delay, tD 8 ns typ VS = 3 V, RL = 300 Ω, CL = 35 pF 1 ns min Charge Injection, QINJ ±3 pC typ VS = 2 V, RS = 0 Ω, CL = 1 nF Off Isolation −60 dB typ RL = 50 Ω, CL = 5 pF, f = 10 MHz −80 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz Channel to Channel Crosstalk −70 dB typ RL = 50 Ω, CL = 5 pF, f = 10 MHz −90 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz −3 dB Bandwidth 155 MHz typ RL = 50 Ω, CL = 5 pF Insertion Loss −0.3 dB typ Off Switch Source Capacitance, CS (OFF) 11 pF typ Off Switch Drain Capacitance, CD (OFF) 11 pF typ On Switch Capacitance, C D (ON), C S (ON) 22 pF typ POWER REQUIREMENTS VDD = 5.5 V Positive Power Supply Current, IDD 10 µA typ Digital inputs = 0 V or 5.5 V 20 µA max
3 V SINGLE SUPPLY
VDD = 3 V ± 10%, VSS = 0 V, and GND = 0 V, unless otherwise noted. Temperature range is −40°C to +85°C.
Table 2. Parameter +25°C −40°C to +85°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance, RON 6 Ω typ VS = 0 V to VDD, IS = 10 mA 11 12 Ω max On Resistance Match Between Channels, ΔRON 0.4 Ω typ VS = 0 V to VDD, IS = 10 mA 1.2 Ω max On Resistance Flatness, RFLAT(ON) 3.5 Ω typ VS = 0 V to VDD, IS = 10 mA LEAKAGE CURRENTS VDD = 3.3 V Source OFF Leakage, IS (OFF) ±0.01 nA typ VS = 3 V/1 V, VD = 1 V/3 V ±0.1 ±0.3 nA max Drain OFF Leakage, ID (OFF) ±0.01 nA typ VS = 1 V/3 V, VD = 3 V/1 V ±0.1 ±0.3 nA max Channel ON Leakage, ID (ON), IS (ON) ±0.01 nA typ VS = VD = 1 V or 3 V ±0.1 ±0.3 nA max DIGITAL INPUTS Input Voltage High, VINH 2.0 V min Low, VINL 0.8 V max High or Low Input Current, IINH or IINL 0.005 µA typ VIN = VINL or VINH ±0.1 µA max Digital Input Capacitance, CIN 3 pF typ DIGITAL OUTPUT, ADG714, DOUT Output Voltage Low, VOL 0.4 V max ISINK = 6 mA Digital Output Capacitance, COUT 4 pF typ Rev. E | Page 4 of 21 Document Outline Features Applications General Description Functional Block Diagrams Product Highlights Revision History Specifications 5 V Single Supply 3 V Single Supply ±2.5 V Dual Supply Timing Characteristics ADG714 ADG715 Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Power-On Reset Serial Interface 3-Wire Serial Interface 2-Wire Serial Interface Input Shift Register Write Operation Read Operation Applications Information Multiple Devices on One Bus Daisy-Chaining Multiple ADG714 Devices Power Supply Sequencing Decoding Multiple ADG714 Devices Using the ADG739 Outline Dimensions Ordering Guide
