Datasheet ADG714, ADG715 (Analog Devices) - 5
DescriptionCMOS, Low Voltage Serially Controlled, Octal SPST Switches
Pages / Page21 / 5 — Data Sheet. ADG714/. ADG715. Parameter. +25°C. −40°C to +85°C. Unit. Test …
RevisionE
File Format / SizePDF / 368 Kb
Data Sheet. ADG714/. ADG715. Parameter. +25°C. −40°C to +85°C. Unit. Test Conditions/Comments. ±2.5 V DUAL SUPPLY. Table 3. Parameter
Data Sheet ADG714/ ADG715 Parameter +25°C −40°C to +85°C Unit Test Conditions/Comments ±2.5 V DUAL SUPPLY Table 3 Parameter
DIGITAL INPUTS, SCL, SDA Input Voltage High, VINH 0.7 × VDD V min VDD + 0.3 V max Low, VINL −0.3 V min 0.3 × VDD V max Input Leakage Current, IIN 0.005 µA typ VIN = 0 V to VDD ±1 µA max Input Hysteresis, VHYST 0.05 × VDD V min Input Capacitance, CIN 6 pF typ LOGIC OUTPUT, (SDA) Output Voltage Low, VOL 0.4 V max ISINK = 3 mA 0.6 V max ISINK = 6 mA DYNAMIC CHARACTERISTICS On Time, tON ADG714 35 ns typ VS = 2 V, RL = 300 Ω, CL = 35 pF 65 ns max ADG715 130 ns typ VS = 2 V, RL = 300 Ω, CL = 35 pF 200 ns max Off Time, tOFF ADG714 11 ns typ VS = 2 V, RL = 300 Ω, CL = 35 pF 20 ns max ADG715 115 ns typ VS = 2 V, RL = 300 Ω, CL = 35 pF 180 ns max Break-Before-Make Time Delay, tD 8 ns typ VS = 2 V, RL = 300 Ω, CL = 35 pF 1 ns min Charge Injection, QINJ ±2 pC typ VS = 1.5 V, RS = 0 Ω, CL = 1 nF Off Isolation −60 dB typ RL = 50 Ω, CL = 5 pF, f = 10 MHz −80 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz Channel to Channel Crosstalk −70 dB typ RL = 50 Ω, CL = 5 pF, f = 10 MHz −90 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz –3 dB Bandwidth 155 MHz typ RL = 50 Ω, CL = 5 pF Insertion Loss −0.4 dB typ Off Switch Source Capacitance, CS (OFF) 11 pF typ Off Switch Drain Capacitance, CD (OFF) 11 pF typ On Switch Capacitance, C D (ON), C S (ON) 22 pF typ POWER REQUIREMENTS VDD = 3.3 V Positive Power Supply Current, IDD 10 µA typ Digital inputs = 0 V or 3.3 V 20 µA max
±2.5 V DUAL SUPPLY
VDD = +2.5 V ± 10%, VSS = −2.5 V ± 10%, and GND = 0 V, unless otherwise noted. Temperature range is −40°C to +85°C.
Table 3. Parameter +25°C −40°C to +85°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range VSS to VDD V On Resistance, RON 2.5 Ω typ VS = VSS to VDD, IDS = 10 mA 4.5 5 Ω max On Resistance Match Between Channels, ΔRON 0.4 Ω typ VS = VSS to VDD, IDS = 10 mA 0.8 Ω max On Resistance Flatness, RFLAT(ON) 0.6 Ω typ VS = VSS to VDD, IDS = 10 mA 1 Ω max Rev. E | Page 5 of 21 Document Outline Features Applications General Description Functional Block Diagrams Product Highlights Revision History Specifications 5 V Single Supply 3 V Single Supply ±2.5 V Dual Supply Timing Characteristics ADG714 ADG715 Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Power-On Reset Serial Interface 3-Wire Serial Interface 2-Wire Serial Interface Input Shift Register Write Operation Read Operation Applications Information Multiple Devices on One Bus Daisy-Chaining Multiple ADG714 Devices Power Supply Sequencing Decoding Multiple ADG714 Devices Using the ADG739 Outline Dimensions Ordering Guide
