Datasheet ADG714, ADG715 (Analog Devices) - 6
DescriptionCMOS, Low Voltage Serially Controlled, Octal SPST Switches
Pages / Page21 / 6 — ADG714/. ADG715. Data Sheet. Parameter. +25°C. −40°C to +85°C Unit. Test …
RevisionE
File Format / SizePDF / 368 Kb
ADG714/. ADG715. Data Sheet. Parameter. +25°C. −40°C to +85°C Unit. Test Conditions/Comments
ADG714/ ADG715 Data Sheet Parameter +25°C −40°C to +85°C Unit Test Conditions/Comments
LEAKAGE CURRENTS VDD = +2.75 V, VSS = −2.75 V Source Off Leakage, IS (OFF) ±0.01 nA typ VS = +2.25 V/−1.25 V, VD = −1.25 V/+2.25 V ±0.1 ±0.3 nA max Drain Off Leakage, ID (OFF) ±0.01 nA typ VS = +2.25 V/−1.25 V, VD = −1.25 V/+2.25 V ±0.1 ±0.3 nA max Channel On Leakage, ID (ON), IS (ON) ±0.01 nA typ VS = VD = +2.25 V/−1.25 V ±0.1 ±0.3 nA max DIGITAL INPUTS Input Voltage High, VINH 1.7 V min Low, VINL 0.7 V max High or Low Input Current, IINH or IINL 0.005 µA typ VIN = VINL or VINH ±0.1 µA max Digital Input Capacitance, CIN 3 pF typ DIGITAL OUTPUT, ADG714, DOUT Output Voltage Low, VOL 0.4 V max ISINK = 6 mA Digital Output Capacitance, COUT 4 pF typ DIGITAL INPUTS, SCL, SDA Input Voltage High, VINH 0.7 × VDD V min VDD + 0.3 V max High, VINH −0.3 V min 0.3 × VDD V max Input Leakage Current, IIN 0.005 µA typ VIN = 0 V to VDD ±1 µA max Input Hysteresis, VHYST 0.05 × VDD V min Input Capacitance, CIN 6 pF typ LOGIC OUTPUT, SDA Output Voltage Low, VOL 0.4 V max ISINK = 3 mA 0.6 V max ISINK = 6 mA DYNAMIC CHARACTERISTICS On Time, tON ADG714 20 ns typ VS = 1.5 V, RL = 300 Ω, CL = 35 pF 32 ns max ADG715 133 ns typ VS = 1.5 V, RL = 300 Ω, CL = 35 pF 200 ns max Off Time, tOFF ADG714 8 ns typ VS = 1.5 V, RL = 300 Ω, CL = 35 pF 18 ns max ADG715 124 ns typ VS = 1.5 V, RL = 300 Ω, CL = 35 pF 190 ns max Break-Before-Make Time Delay, tD 8 ns typ VS = 1.5 V, RL = 300 Ω, CL = 35 pF 1 ns min Charge Injection, QINJ ±3 pC typ VS = 0 V, RS = 0 Ω, CL = 1 nF Off Isolation −60 dB typ RL = 50 Ω, CL = 5 pF, f = 10 MHz −80 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz Channel to Channel Crosstalk −70 dB typ RL = 50 Ω, CL = 5 pF, f = 10 MHz −90 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz −3 dB Bandwidth 155 MHz typ RL = 50 Ω, CL = 5 pF Insertion Loss −0.3 dB typ Rev. E | Page 6 of 21 Document Outline Features Applications General Description Functional Block Diagrams Product Highlights Revision History Specifications 5 V Single Supply 3 V Single Supply ±2.5 V Dual Supply Timing Characteristics ADG714 ADG715 Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Power-On Reset Serial Interface 3-Wire Serial Interface 2-Wire Serial Interface Input Shift Register Write Operation Read Operation Applications Information Multiple Devices on One Bus Daisy-Chaining Multiple ADG714 Devices Power Supply Sequencing Decoding Multiple ADG714 Devices Using the ADG739 Outline Dimensions Ordering Guide
