Datasheet ADG451, ADG452, ADG453 (Analog Devices) - 10
Description5 Ω RON SPST Switches
Pages / Page16 / 10 — ADG451/ADG452/ADG453. 0.5 V. 120. DD = +15V. VDD = +15V. 0.4 VSS = –15V. …
RevisionC
File Format / SizePDF / 414 Kb
ADG451/ADG452/ADG453. 0.5 V. 120. DD = +15V. VDD = +15V. 0.4 VSS = –15V. VSS = –15V. TA = +25°C. VL = +5V. 0.3 VL = +5V. 100. RLOAD = 50Ω. 0.2
ADG451/ADG452/ADG453 0.5 V 120 DD = +15V VDD = +15V 0.4 VSS = –15V VSS = –15V TA = +25°C VL = +5V 0.3 VL = +5V 100 RLOAD = 50Ω 0.2
ADG451/ADG452/ADG453 0.5 V 120 DD = +15V VDD = +15V 0.4 VSS = –15V VSS = –15V TA = +25°C VL = +5V 0.3 VL = +5V 100 RLOAD = 50Ω A) 0.2 n ( ID (ON) ) 80 NT 0.1 I B S (OFF) d RRE K ( 0 ID (OFF) L A 60 CU T E –0.1 S S 40 AKAG –0.2 CRO E L –0.3 20 –0.4
9
–0.5 0
-00
–15 –12 –9 –6 –3 0 3 6 9 12 15
11 9 0
100 1k 10k 100k 1M 10M 100M
9- 23
VD OR VS DRAIN OR SOURCE VOLTAGE (V)
23 05
FREQUENCY (Hz)
05 Figure 11. Leakage Currents as a Function of VD (VS) Figure 13. Crosstalk vs. Frequency
70 0 VDD = +15V VDD = +15V VSS = –15V VSS = –15V 60 VL = +5V –0.5 VL = +5V 50 –1.0 B) d N ( 40 ) –1.5 IO dB AT ( L S S O 30 –2.0 S I LO F F O 20 –2.5 10 –3.0 0 –3.5
10 12 0
1 10 100
0 9-
1 10 100 200
9- 23
FREQUENCY (MHz)
23
FREQUENCY (MHz)
05 05 Figure 12. Off Isolation vs. Frequency Figure 14. Frequency Response with Switch On Rev. C | Page 10 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENTS REVISION HISTORY PRODUCT HIGHLIGHTS SPECIFICATIONS 15 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY APPLICATIONS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
