Datasheet ADG438F, ADG439F (Analog Devices) - 7
DescriptionHigh Performance, 4-/8-Channel, Fault-Protected Analog Multiplexers
Pages / Page16 / 7 — ADG438F/ADG439F. TYPICAL PERFORMANCE CHARACTERISTICS. 2000. TA = 25°C. …
RevisionE
File Format / SizePDF / 325 Kb
ADG438F/ADG439F. TYPICAL PERFORMANCE CHARACTERISTICS. 2000. TA = 25°C. 1750. DD = +15V. VSS = –15V. VDD = +5V. 1500. VSS = –5V. TA = 125°C
ADG438F/ADG439F TYPICAL PERFORMANCE CHARACTERISTICS 2000 TA = 25°C 1750 DD = +15V VSS = –15V VDD = +5V 1500 VSS = –5V TA = 125°C
ADG438F/ADG439F TYPICAL PERFORMANCE CHARACTERISTICS 2000 2000 TA = 25°C V 1750 1750 DD = +15V VSS = –15V VDD = +5V 1500 VSS = –5V 1500 TA = 125°C TA = 105°C T 1250 A = 85°C V 1250 ) DD = +10V T ) A = 25°C VSS = –10V ( 1000 ( 1000 ONR ON V R DD = +15V 750 VSS = –15V 750 500 500 250 250 0 0 –15 –10 –5 0 5 10 15
08 1 0 1 0 8-
–15 –10 –5 0 5 10 15 VD, VS (V)
46
V
00
D, VS (V)
00468- Figure 5. On Resistance as a Function of VD (VS) Figure 8. On Resistance as a Function of VD (VS) for Different Temperatures
1m 1m 100µ VDD = 0V 100µ V V DD = +15V SS = 0V V 10µ V SS = –15V D = 0V 10µ VD = 0V (A) E (A) E OPERATING RANGE 100n 100n AKAG E AKAG E L 10n L 10n UT UT OPERATING RANGE INP 1n INP 1n I S I S 100p 100p 10p 10p 1p
9
1p
2
–50 –40 –30 –20 –10 0 10 20 30 40 50 60
00
–40
01 8-
–50 –30 –20 –10 0 10 20 30 40 50 60
8-
VS SOURCE VOLTAGE (V) V
0046
0046 Figure 6. Source Input Leakage Current as a Function of VS (Power Supplies Off) Figure 9. Source Input Leakage Current as a Function of VS (Power Supplies On) During Overvoltage Conditions During Overvoltage Conditions
1m 0.3 100µ V V DD = +15V DD = +15V V V SS = –15V SS = –15V 0.2 V 10µ V S (VD) = ±10V D = 0V T ) A) A = 25°C n (A ( E S 0.1 G A NT K 100n E A 0.0 I URR D (OFF) 10n T LE C U E P I IN 1n S (OFF) KAG –0.1 I D OPERATING RANGE A E 100p L –0.2 I 10p D, IS (ON) 1p
0
–0.3 –50 –40 –30 –20 –10 0 10 20 30 40 50 60
01 8-
–14 –10 –6 –2 2 6 10 14
013
468- 0046
S, VD (V)
00 Figure 7. Drain Output Leakage Current as a Function of VS (Power Supplies On) Figure 10. Leakage Currents as a Function of VD (VS) During Overvoltage Conditions Rev. E | Page 7 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY THEORY OF OPERATION OUTLINE DIMENSIONS ORDERING GUIDE
