Datasheet ADG417 (Analog Devices) - 5
DescriptionLC2MOS Precision Mini-DIP Analog Switch
Pages / Page8 / 5 — Typical Performance Characteristics–ADG417. 100. A = +25. VDD = +5V. VSS …
File Format / SizePDF / 97 Kb
Typical Performance Characteristics–ADG417. 100. A = +25. VDD = +5V. VSS = –5V. VDD = +5V VSS = 0V. DD = +12V. VSS = –12V. DD = +10V
Typical Performance Characteristics–ADG417 100 A = +25 VDD = +5V VSS = –5V VDD = +5V VSS = 0V DD = +12V VSS = –12V DD = +10V
Typical Performance Characteristics–ADG417 50 100 T T A = +25
8
C VDD = +5V A = +25
8
C VSS = –5V 40 80 VDD = +5V VSS = 0V V 30 DD = +12V 60
V
VSS = –12V
V
V DD = +10V V V SS = –10V DD = +10V ON ON R R VSS = 0V V 20 40 DD = +12V VSS = 0V V DD = +15V 10 VSS = –15V 20 VDD = +15V VSS = 0V 0 0 –15 –10 –5 0 5 10 15 0 5 10 15 V V S, VD – Volts S, VD – Volts
Figure 1. RON as a Function of VD (VS): Dual Supply Voltage Figure 4. RON as a Function of VD (VS): Single Supply Voltage
50 100 VDD = +15V VSS = –15V VDD = +12V VL = +5V V 40 80 SS = 0V VL = +5V 30 60
V V
+125
8
C ON +125
8
C ON R R 20 40 +85
8
C +85
8
C +25
8
C +25
8
C 10 20 0 0 –15 –10 –5 0 5 10 15 0 3 6 9 12 V V S, VD – Volts S, VD – Volts
Figure 2. RON as a Function of VD (VS) for Different Figure 5. RON as a Function of VD (VS) for Different Temperatures Temperatures
0.02 0.006 VDD = +15V VDD = +12V VSS = –15V V I SS = 0V D (ON) TA = +25
8
C TA = +25
8
C 0.01 0.004 ID (ON) IS (OFF) ID (OFF) 0.00 0.002 IS (OFF) ID (OFF) –0.01 0.000 LEAKAGE CURRENT – nA LEAKAGE CURRENT – nA –0.02 –0.002 –0.03 –0.004 –15 –10 –5 0 5 10 15 0 2 4 6 8 10 12 VS, VD – Volts VS, VD – Volts
Figure 3. Leakage Currents as a Function of VS (VD) Figure 6. Leakage Currents as a Function of VS (VD) REV. A –5–
