Datasheet ADG508F, ADG509F (Analog Devices) - 5
Description8-Channel/4-Channel Fault-Protected Analog Multiplexers
Pages / Page20 / 5 — ADG508F/ADG509F. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter Rating. ESD …
RevisionF
File Format / SizePDF / 289 Kb
ADG508F/ADG509F. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter Rating. ESD CAUTION
ADG508F/ADG509F ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
T Stresses above those listed under Absolute Maximum Ratings A = 25°C unless otherwise noted. may cause permanent damage to the device. This is a stress
Table 4.
rating only; functional operation of the device at these or any
Parameter Rating
other conditions above those indicated in the operational VDD to VSS 48 V section of this specification is not implied. Exposure to absolute VDD to GND −0.3 V to +48 V maximum rating conditions for extended periods may affect VSS to GND +0.3 V to −48 V device reliability. Digital Input, EN, Ax −0.3 V to VDD + 0.3 V or 20 mA, whichever occurs first VS, Analog Input Overvoltage with VSS − 25 V to VDD + 40 V
ESD CAUTION
Power On (VDD = +15 V, VSS = −15 V) VS, Analog Input Overvoltage with −40 V to +55 V Power Off (VDD = 0 V, VSS = 0 V) Continuous Current, S or D 20 mA Peak Current, S or D (Pulsed at 1 ms, 10% Duty Cycle Max) 40 mA Operating Temperature Range Industrial (B Version) −40°C to +85°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C TSSOP θJA, Thermal Impedance 112°C/W Plastic DIP Package θJA, Thermal Impedance 16-Lead 117°C/W SOIC Package θJA, Thermal Impedance Narrow Body 77°C/W Wide Body 75°C/W Rev. F | Page 5 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY TRUTH TABLES ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
