Datasheet ADG508F, ADG509F (Analog Devices) - 6
Description8-Channel/4-Channel Fault-Protected Analog Multiplexers
Pages / Page20 / 6 — ADG508F/ADG509F. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. A0 1. 16 …
RevisionF
File Format / SizePDF / 289 Kb
ADG508F/ADG509F. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. A0 1. 16 A1. EN 2. 15 A2. VSS 3. 14 GND. ADG508F. S1 4. TOP VIEW. 13 VDD
ADG508F/ADG509F PIN CONFIGURATION AND FUNCTION DESCRIPTIONS A0 1 16 A1 EN 2 15 A2 VSS 3 14 GND ADG508F S1 4 TOP VIEW 13 VDD
ADG508F/ADG509F PIN CONFIGURATION AND FUNCTION DESCRIPTIONS A0 1 16 A1 EN 2 15 A2 VSS 3 14 GND ADG508F S1 4 TOP VIEW 13 VDD S2 (Not to Scale) 5 12 S5 S3 6 11 S6 S4 7 10 S7
4 00
D
5-
8 9 S8
03 00 Figure 3. ADG508F Pin Configuration
Table 5. ADG508F Pin Function Descriptions Pin No. Mnemonic Description
1 A0 Logic Control Input. 2 EN Active High Digital Input. When low, the device is disabled and all switches are off. When high, Ax logic inputs determine on switches. 3 VSS Most Negative Power Supply Potential. In single-supply applications, this pin can be connected to ground. 4 S1 Source Terminal 1. This pin can be an input or an output. 5 S2 Source Terminal 2. This pin can be an input or an output. 6 S3 Source Terminal 3. This pin can be an input or an output. 7 S4 Source Terminal 4. This pin can be an input or an output. 8 D Drain Terminal. This pin can be an input or an output. 9 S8 Source Terminal 8. This pin can be an input or an output. 10 S7 Source Terminal 7. This pin can be an input or an output. 11 S6 Source Terminal 6. This pin can be an input or an output. 12 S5 Source Terminal 5. This pin can be an input or an output. 13 VDD Most Positive Power Supply Potential. 14 GND Ground (0 V) Reference. 15 A2 Logic Control Input. 16 A1 Logic Control Input. Rev. F | Page 6 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY TRUTH TABLES ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
