Datasheet ADG508F, ADG509F (Analog Devices) - 9 Manufacturer Analog Devices Description 8-Channel/4-Channel Fault-Protected Analog Multiplexers Pages / Page 20 / 9 — ADG508F/ADG509F. 100. TA = 25°C. VDD = +15V. DD = +15V. –20. SS = –15V. D … Revision F File Format / Size PDF / 289 Kb Document Language English
ADG508F/ADG509F. 100. TA = 25°C. VDD = +15V. DD = +15V. –20. SS = –15V. D = +10V. VS = –10V. ( S. –40. D (OFF). N O. RRE. –60. D (ON). F IS. KAG. –80. E L. 0.1
Model Line for this Datasheet Text Version of Document ADG508F/ADG509F 100 0 TA = 25°C V VDD = +15V DD = +15V V –20 V SS = –15V SS = –15V ) V A 10 D = +10V n VS = –10V ) ( S –40 I dB D (OFF) ( NT N O RRE TI 1 I –60 D (ON) LA CU O E F IS KAG –80 A OF E L 0.1 IS (OFF) –100 14 0 5- 030.01 00–120 3 125 35 45 55 65 75 85 95 105 115 125 1k 10k 100k 1M 10M 100M 1G -1 54TEMPERATURE (°C) 03FREQUENCY (Hz) 00 Figure 11. Leakage Currents as a Function of Temperature Figure 14. Off Isolation vs. Frequency, ±15 V Dual Supply260 40 TA = 25°C 240 35 VDD = +15V t V TRANSITION SS = –15V 220 30 ) F s) p ( (n E 200 t 25 ON (EN) M NCE DRAIN OFF G TI 180 ITA 20 IN AC H P C 160 15 IT CA W IN S P 140 10 tOFF (EN) 120 5 15SOURCE OFF 0 5- 03100 000 –15 –10 –5 0 5 10 15 410 11 12 13 14 15 1 1 5-POWER SUPPLY (V) VS (V) 03 00 Figure 12. Switching Time vs. Dual Power Supply Figure 15. Capacitance vs. Source Voltage300 30 VDD = +15V VDD = +15V VSS = –15V VSS = –15V 250 t T ON (EN) 20 A = 25°C s) n 200 10 ( E tTRANSITION ) IM C G T 150 (p J 0 IN IN H Q C IT 100 W tOFF (EN) –10 S 50 –20 6 01 5- 030 00–30 15 1–40 –20 0 20 40 60 80 100 120 –15 –10 –5 0 5 10 15 5- 03TEMPERATURE (°C) V S (V) 00 Figure 13. Switching Time vs. Temperature Figure 16. Charge Injection vs. Source Voltage Rev. F | Page 9 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY TRUTH TABLES ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
