Datasheet ADG406, ADG407, ADG426 (Analog Devices) - 10
DescriptionLC2MOS 8-/16-Channel High Performance Analog Multiplexers
Pages / Page20 / 10 — ADG406/ADG407/ADG426. VDD 1. 28 DA. DB 2. 27 VSS. S8B. NC 3. 26 S8A. 28 …
File Format / SizePDF / 394 Kb
ADG406/ADG407/ADG426. VDD 1. 28 DA. DB 2. 27 VSS. S8B. NC 3. 26 S8A. 28 27 26. S8B 4. 25 S7A. S7B 5. PIN 1. 24 S6A. INDENTFIER. ADG407. S6B 6. 23 S5A
ADG406/ADG407/ADG426 VDD 1 28 DA DB 2 27 VSS S8B NC 3 26 S8A 28 27 26 S8B 4 25 S7A S7B 5 PIN 1 24 S6A INDENTFIER ADG407 S6B 6 23 S5A
ADG406/ADG407/ADG426 VDD 1 28 DA A DD SS DB 2 27 VSS S8B NC DB V DA V S8 NC 3 26 S8A 4 3 2 1 28 27 26 S8B 4 25 S7A S7B 5 PIN 1 25 S7A S7B 5 24 S6A INDENTFIER ADG407 S6B 6 24 S6A S6B 6 23 S5A TOP VIEW S5B 7 22 S4A S5B 7 23 S5A (Not to Scale) ADG407 S4B 8 21 S3A S4B 8 TOP VIEW 22 S4A S3B 9 20 S2A (Not to scale) S3B 9 21 S3A S2B 10 19 S1A S2B 10 20 S2A S1B 11 18 EN S1B 11 19 S1A GND 12 17 A0 NC 13 16 A1 12 13 14 15 16 17 18
7 6 00
NC 14 15 A2
00
D
6- 6-
NC NC A2 A1 A0 EN
02 02
GN
00
NC = NO CONNECT
00
NC = NO CONNECT
Figure 8. 28-Lead PDIP Figure 9. 28-Lead PLCC
Table 6. Pin Function Descriptions Pin No. Mnemonic Description
1 VDD Most Positive Power Supply Potential. 2 DB Drain Terminal B. This pin can be an input or an output. 3, 13, 14 NC No Connect. 4 to 11 S8B to S1B Source Terminal 8B to Source Terminal 1B. These pins can be inputs or outputs. 12 GND Ground (0 V) Reference. 15 to 17 A2 to A0 Logic Control Input. 18 EN Active High Digital Input. When this pin is low, the device is disabled and all switches are turned off. When this pin is high, the Ax logic inputs determine which switch is turned on. 19 to 26 S1A to S8A Source Terminal 1A to Source Terminal 8A. These pins can be inputs or outputs. 27 VSS Most Negative Power Supply Potential. In single-supply applications, this pin can be connected to ground. 28 DA Drain Terminal A. This pin can be an input or an output.
Table 7. Truth Table (ADG407) A2 A1 A0 EN On Switch Pair
X X X 0 None 0 0 0 1 1 0 0 1 1 2 0 1 0 1 3 0 1 1 1 4 1 0 0 1 5 1 0 1 1 6 1 1 0 1 7 1 1 1 1 8 Rev. B | Page 10 of 20 Document Outline FEATURES APPLICATIONS PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ADG426 TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
