Datasheet ADG406, ADG407, ADG426 (Analog Devices) - 8
DescriptionLC2MOS 8-/16-Channel High Performance Analog Multiplexers
Pages / Page20 / 8 — ADG406/ADG407/ADG426. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter …
RevisionB
File Format / SizePDF / 394 Kb
ADG406/ADG407/ADG426. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter Rating. ESD CAUTION
ADG406/ADG407/ADG426 ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
link to page 8
TA = 25°C unless otherwise noted. Stresses above those listed under Absolute Maximum Ratings
Table 3.
may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any
Parameter Rating
other conditions above those indicated in the operational VDD to VSS 44 V section of this specification is not implied. Exposure to absolute VDD to GND −0.3 V to +25 V maximum rating conditions for extended periods may affect VSS to GND +0.3 V to −25 V device reliability. Analog, Digital Inputs1 VSS − 2 V to VDD + 2 V or 20 mA, whichever occurs first
ESD CAUTION
Continuous Current, S or D 20 mA Peak Current, S or D 40 mA (Pulsed at 1 ms, 10% duty cycle max) Operating Temperature Range Industrial (B Version) −40°C to +85°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C Plastic Package θJA, Thermal Impedance 75°C/W Lead Temperature, Soldering 260°C (10 sec) PLCC Package θJA, Thermal Impedance 80°C/W Lead Temperature, Soldering Vapor Phase (60 sec) 215°C Infrared (15 sec) 220°C SSOP Package θJA, Thermal Impedance 122°C/W Lead Temperature, Soldering Vapor Phase (60 sec) 215°C Infrared (15 sec) 220°C 1 Overvoltages at A, S, D, WR, or RS will be clamped by internal diodes. Current should be limited to the maximum ratings given. Rev. B | Page 8 of 20 Document Outline FEATURES APPLICATIONS PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ADG426 TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
