Datasheet ADG441, ADG442, ADG444 (Analog Devices) - 9
Description | LC2MOS Quad SPST Switches |
Pages / Page | 16 / 9 — Data Sheet. ADG441/ADG442/ADG444. TEST CIRCUITS. IDS. IS (OFF). ID (OFF). … |
Revision | B |
File Format / Size | PDF / 315 Kb |
Data Sheet. ADG441/ADG442/ADG444. TEST CIRCUITS. IDS. IS (OFF). ID (OFF). ID (ON). RON = V1/IDS. +15V. +5V. 0.1. VIN. 50%. ADG441/ADG444. VOUT. 35pF
Data Sheet ADG441/ADG442/ADG444 TEST CIRCUITS IDS IS (OFF) ID (OFF) ID (ON) V1 S D S D A A A V S D VS VD S VD V
05233-016 05233-017
S RON = V1/IDS
05233-015 Figure 14. On Resistance Figure 15. Off Leakage Figure 16. On Leakage
+15V +5V 3V 0.1
F 0.1
F VIN 50% 50% ADG441/ADG444 V V DD L S D VOUT 3V V R C S L L 1k 35pF VIN 50% 50% ADG442 IN GND V 90% 90% SS VOUT 0.1
F tON tOFF –15V
05233-018 Figure 17. Switching Times
+15V +5V 3V V V DD L RS S D VOUT VIN V C S L 1nF IN VOUT
VOUT GND VSS QINJ = CL ×
VOUT –15V
05233-019 Figure 18. Charge Injection Rev. B | Page 9 of 16 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Table of Contents Revision History Specifications Dual Supply Single Supply Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Trench Isolation Outline Dimensions Ordering Guide
