Datasheet ADG408, ADG409 (Analog Devices) - 7
DescriptionDatasheet LC2MOS 4-/8-Channel High Performance Analog Multiplexers
Pages / Page15 / 7 — Data Sheet. ADG408/ADG409. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. …
RevisionD
File Format / SizePDF / 259 Kb
Data Sheet. ADG408/ADG409. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. A0 1. 16 A1. EN 2. 15 A2. 15 GND. ADG409. ADG408. 14 GND. 14 VDD
Data Sheet ADG408/ADG409 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS A0 1 16 A1 EN 2 15 A2 15 GND ADG409 ADG408 14 GND 14 VDD
Data Sheet ADG408/ADG409 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS A0 1 16 A1 A0 1 16 A1 EN 2 15 A2 EN 2 15 GND V V ADG409 SS 3 ADG408 14 GND SS 3 14 VDD TOP VIEW S1 TOP VIEW 4 13 VDD S1A 4 13 S1B (Not to Scale) (Not to Scale) S2 5 12 S5 S2A 5 12 S2B S3 6 11 S6 S3A 6 11 S3B S4 S4A 7 10 S4B 10 S7 7
02 0 -003
D
7-
DA 8 9 DB 8 9 S8
02 00027 00 Figure 2. ADG408 Pin Configuration Figure 3. ADG409 Pin Configuration
Table 4. ADG408 Pi n Function Descriptions Table 5. ADG409 Pi n Function Descriptions Pin Pin No. Mnemonic Description No. Mnemonic Description
1 A0 Logic Control Input. 1 A0 Logic Control Input. 2 EN Active High Digital Input. When low, the 2 EN Active High Digital Input. When low, the device is disabled and all switches are off. device is disabled and all switches are off. When high, Ax logic inputs determine on When high, Ax logic inputs determine on switches. switches. 3 VSS Most Negative Power Supply Potential in 3 VSS Most Negative Power Supply Potential in Dual Supplies. In single-supply applications, Dual Supplies. In single-supply applications, it can be connected to ground. it can be connected to ground. 4 S1 Source Terminal 1. Can be an input or 4 S1A Source Terminal 1A. Can be an input or an output. an output. 5 S2 Source Terminal 2. Can be an input or 5 S2A Source Terminal 2A. Can be an input or an output. an output. 6 S3 Source Terminal 3. Can be an input or 6 S3A Source Terminal 3A. Can be an input or an output. an output. 7 S4 Source Terminal 4. Can be an input or 7 S4A Source Terminal 4A. Can be an input or an output. an output. 8 D Drain Terminal. Can be an input or an 8 DA Drain Terminal A. Can be an input or an output. output. 9 S8 Source Terminal 8. Can be an input or 9 DB Drain Terminal B. Can be an input or an an output. output. 10 S7 Source Terminal 7. Can be an input or 10 S4B Source Terminal 4B. Can be an input or an output. an output. 11 S6 Source Terminal 6. Can be an input or 11 S3B Source Terminal 3B. Can be an input or an output. an output. 12 S5 Source Terminal 5. Can be an input or 12 S2B Source Terminal 2B. Can be an input or an output. an output. 13 VDD Most Positive Power Supply Potential. 13 S1B Source Terminal 1B. Can be an input or 14 GND Ground (0 V) Reference. an output. 15 A2 Logic Control Input. 14 VDD Most Positive Power Supply Potential. 16 A1 Logic Control Input. 15 GND Ground (0 V) Reference. 16 A1 Logic Control Input.
Table 6. ADG408 Truth Table Table 7. ADG409 Truth Table A2 A1 A0 EN On Switch On Switch
X X X 0 None
A1 A0 EN Pair
0 0 0 1 1 X X 0 None 0 0 1 1 2 0 0 1 1 0 1 0 1 3 0 1 1 2 0 1 1 1 4 1 0 1 3 1 0 0 1 5 1 1 1 4 1 0 1 1 6 1 1 0 1 7 1 1 1 1 8 Rev. D | Page 7 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
