Datasheet ADG428, ADG429 (Analog Devices) - 6
DescriptionLC2MOS Latchable 4-/8-Channel High Performance Analog Multiplexers
Pages / Page12 / 6 — ADG428/ADG429. TIMING DIAGRAMS. 50%. OFF (RS). SWITCH. 0.8VO. A0, A1, …
RevisionC
File Format / SizePDF / 164 Kb
ADG428/ADG429. TIMING DIAGRAMS. 50%. OFF (RS). SWITCH. 0.8VO. A0, A1, (A2). OUTPUT. 0.8V. Typical Characteristics. 140. 600. TA = +25. 130. 550
ADG428/ADG429 TIMING DIAGRAMS 50% OFF (RS) SWITCH 0.8VO A0, A1, (A2) OUTPUT 0.8V Typical Characteristics 140 600 TA = +25 130 550
ADG428/ADG429 TIMING DIAGRAMS 3V 3V 50% 50% WR RS 50% 50% 0V 0V t t RS W t t OFF (RS) S tH 3V VO 2V SWITCH 0.8VO A0, A1, (A2) OUTPUT EN 0.8V 0V 0V
Figure 1. Figure 2. Figure 1 shows the timing sequence for latching the switch Figure 2 shows the Reset Pulsewidth, tRS, and the Reset Turnoff address and enable inputs. The latches are level sensitive; there- Time, tOFF, (RS). fore, while WR is held low, the latches are transparent and the Note: All digital input signals rise and fall times are measured switches respond to the address and enable inputs. This input from 10% to 90% of 3 V. tr = tf = 20 ns. data is latched on the rising edge of WR.
8
C T 130 550 A = +25
8
C 500 120 VDD = +5V 450 V V 110 DD = +5V SS = 0V VSS = –5V 400 100
V
350
V
90 – 300 ON V R ON DD = +10V 80 R 250 VSS = 0V VDD = +15V VDD = +15V V V DD = +12V DD = +12V 200 70 VSS = –15V VDD = +10V VSS = 0V V V SS = 0V SS = –12V VSS = –10V 150 60 100 50 50 40 0 –15 –10 –5 0 5 10 15 0 3 6 9 12 15 VD (VS) – Volts VD (VS) – Volts
Figure 3. RON as a Function of VD (VS): Dual Supply Figure 5. RON as a Function of VD (VS): Single Supply Voltage Voltage
80 160 VDD = +15V VDD = +12V 150 75 VSS = –15V VSS = 0V 140 70 130 65 120
V V
+125
8
C 60 – 110 ON ON R R 100 +85
8
C 55 +125
8
C +85
8
C 90 50 +25
8
C 80 45 +25
8
C 70 40 60 –15 –10 –5 0 5 10 15 0 2 4 6 8 10 15 VD (VS) – Volts VD (VS) – Volts
Figure 4. RON as a Function of VD (VS) for Different Figure 6. RON as a Function of VD (VS) for Different Temperatures Temperatures –6– REV. C
