Datasheet ADG411, ADG412, ADG413 (Analog Devices) - 4
DescriptionLC2MOS Precision Quad SPST Switches
Pages / Page16 / 4 — ADG411/ADG412/ADG413. SINGLE SUPPLY. Table 2. B Version. T Version. …
RevisionD
File Format / SizePDF / 222 Kb
ADG411/ADG412/ADG413. SINGLE SUPPLY. Table 2. B Version. T Version. Parameter. +25°C. −40°C to + 85°C. −55°C to +125°C. Unit
ADG411/ADG412/ADG413 SINGLE SUPPLY Table 2 B Version T Version Parameter +25°C −40°C to + 85°C −55°C to +125°C Unit
link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 12 link to page 12 link to page 4 link to page 4
VDD = 12 V ± 10%, VSS = 0 V, VL = 5 V ± 10%, GND = 0 V, unless otherwise noted.1
Table 2. B Version T Version Parameter +25°C −40°C to + 85°C +25°C −55°C to +125°C Unit Test Conditions/Comments
ANALOG SIGNAL RANGE 0 V to VDD 0 V to VDD V RON 40 40 Ω typ 0 < VD = 8.5 V, IS = −10 mA; 80 100 80 100 Ω max VDD = 10.8 V LEAKAGE CURRENTS VDD = 13.2 V Source OFF Leakage IS (OFF) ±0.1 ±0.1 nA typ VD = 12.2 V/1 V, VS = 1 V/12.2 V; ±0.25 ±5 ±0.25 ±20 nA max Figure 15 Drain OFF Leakage ID (OFF) ±0.1 ±0.1 nA typ VD = 12.2 V/1 V, VS = 1 V/12.2 V; ±0.25 ±5 ±0.25 ±20 nA max Figure 15 Channel ON Leakage ID, IS (ON) ±0.1 ±0.1 nA typ VD = VS = 12.2 V/1 V; ±0.4 ±10 ±0.4 ±40 nA max Figure 16 DIGITAL INPUTS Input High Voltage, VINH 2.4 2.4 V min Input Low Voltage, VINL 0.8 0.8 V max Input Current IINL or IINH 0.005 0.005 μA typ VIN = VINL or VINH ±0.5 ±0.5 μA max DYNAMIC CHARACTERISTICS2 tON 175 175 ns typ RL = 300 Ω, CL = 35 pF; 250 250 ns max VS = 8 V; Figure 17 tOFF 95 95 ns typ RL = 300 Ω, CL = 35 pF; 125 125 ns max VS = 8 V; Figure 17 Break-Before-Make Time 25 25 ns typ RL = 300 Ω, CL = 35 pF; Delay, tD (ADG413 Only) VS1 = VS2 = +10 V; Figure 18 Charge Injection 25 25 pC typ VS = 0 V, RS = 0 Ω, CL = 10 nF; Figure 19 OFF Isolation 68 68 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; Figure 20 Channel-to-Channel Crosstalk 85 85 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; Figure 21 CS (OFF) 9 9 pF typ f = 1 MHz CD (OFF) 9 9 pF typ f = 1 MHz CD, CS (ON) 35 35 pF typ f = 1 MHz POWER REQUIREMENTS VDD = 13.2 V; Digital inputs = 0 V or 5 V IDD 0.0001 0.0001 μA typ 1 5 1 5 μA max IL 0.0001 0.0001 μA typ 1 5 1 5 μA max VL = 5.25 V 1 Temperature ranges are as follows: B versions:−40°C to +85°C; T versions: −55°C to +125°C. 2 Guaranteed by design; not subject to production test.
Table 3. Truth Table (ADG411/ADG412) Table 4. Truth Table (ADG413) ADG411 In ADG412 In Switch Condition Logic Switch 1, 4 Switch 2, 3
0 1 ON 0 OFF ON 1 0 OFF 1 ON OFF Rev. D | Page 4 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY APPLICATIONS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
