Datasheet ADG411, ADG412, ADG413 (Analog Devices) - 9
DescriptionLC2MOS Precision Quad SPST Switches
Pages / Page16 / 9 — ADG411/ADG412/ADG413. TERMINOLOGY RON. tON. S (OFF). tOFF. D (OFF). ID, …
RevisionD
File Format / SizePDF / 222 Kb
ADG411/ADG412/ADG413. TERMINOLOGY RON. tON. S (OFF). tOFF. D (OFF). ID, IS (ON). VD (VS). Crosstalk. CS (OFF). Off Isolation
ADG411/ADG412/ADG413 TERMINOLOGY RON tON S (OFF) tOFF D (OFF) ID, IS (ON) VD (VS) Crosstalk CS (OFF) Off Isolation
Ohmic resistance between D and S. Delay between applying the digital control input and the output
I
switching on.
S (OFF)
Source leakage current with the switch OFF.
tOFF I
D (OFF)
switching off. Drain leakage current with the switch OFF.
tD ID, IS (ON)
OFF time or ON time measured between the 90% points of Channel leakage current with the switch ON. both switches, when switching from one address state to
VD (VS)
another. Analog voltage on terminals D, S.
Crosstalk CS (OFF)
A measure of unwanted signal which is coupled through from OFF switch source capacitance. one channel to another as a result of parasitic capacitance.
C Off Isolation D (OFF)
OFF switch drain capacitance. A measure of unwanted signal coupling through an OFF switch.
C Charge Injection D, CS (ON)
ON switch capacitance. A measure of the glitch impulse transferred from the digital input to the analog output during switching. Rev. D | Page 9 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY APPLICATIONS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
