Datasheet ADG201A-EP (Analog Devices) - 3
DescriptionLC2MOS Quad SPST Switches
Pages / Page8 / 3 — ADG201A-EP. SPECIFICATIONS DUAL SUPPLY. Table 2. Parameter. +25°C. −55°C …
File Format / SizePDF / 178 Kb
ADG201A-EP. SPECIFICATIONS DUAL SUPPLY. Table 2. Parameter. +25°C. −55°C to +125°C. Unit. Test Conditions/Comments
ADG201A-EP SPECIFICATIONS DUAL SUPPLY Table 2 Parameter +25°C −55°C to +125°C Unit Test Conditions/Comments
link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 3 link to page 6 link to page 6 link to page 6 link to page 6 link to page 3 link to page 3 link to page 3
VDD = +15 V ± 10%, VSS = −15 V ± 10%, GND = 0 V. All specifications −55°C to +125°C, unless otherwise noted.
Table 2. Parameter +25°C −55°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range ±15 ±15 V On Resistance (RON) 60 Ω typ −10 V ≤ VS ≤ +10 V, IDS = 1 mA; see Figure 3 90 145 Ω max RON vs. VD(VS) 20 % typ RON Drift 0.5 %/°C typ RON Match 5 % typ VS = 0 V, IDS = 1 mA LEAKAGE CURRENTS Source Off Leakage, IS (Off) ±0.5 nA typ VD = ±14 V, VS = ∓14 V; see Figure 4 ±2.0 ±100 nA max Drain Off Leakage, ID (Off) ±0.5 nA typ VD = ±14 V, VS = ∓14 V; see Figure 4 ±2.0 ±100 nA max Channel On Leakage, ID, IS (On) ±0.5 nA typ VD = ±14 V; see Figure 5 ±2.0 ±200 nA max DIGITAL INPUTS Input High Voltage, VINH 2.4 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 1 μA max DYNAMIC CHARACTERISTICS tOPEN 30 ns typ See Figure 6 tON 1 300 ns max See Figure 6 t 1 OFF 250 ns max See Figure 6 Off Isolation 80 dB typ VS = 10 V p-p, f = 100 kHz, RL = 75 Ω; see Figure 8 Channel-to-Channel Crosstalk 80 dB typ See Figure 9 CS (Off) 5 pF typ CD (Off) 5 pF typ CD, CS (On) 16 pF typ CIN Digital input Capacitance 5 pF typ QINJ Charge Injection 20 pC typ RS = 0 Ω, CL = 1000 pF, VS = 0 V; see Figure 7 POWER SUPPLY IDD 0.6 mA typ Digital inputs= VINL or VINH 2 mA max ISS 0.1 mA typ 0.2 mA max Power Dissipation 33 mW max 1 Sample tested at 25°C to ensure compliance. Rev. 0 | Page 3 of 8 Document Outline Features Enhanced Product Features Functional Block Diagram General Description Product Highlights Revision History Specifications Dual Supply Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Test Circuits Outline Dimensions Ordering Guide
