Datasheet ADG852 (Analog Devices)
Description0.8 Ω CMOS, 1.8 V to 5.5 V, SPDT/2:1 Mux Mini LFCSP
Pages / Page16 / 1 — 0.8 Ω CMOS, 1.8 V to 5.5 V,. SPDT/2:1 Mux Mini LFCSP. Data Sheet. ADG852. …
RevisionB
File Format / SizePDF / 205 Kb
0.8 Ω CMOS, 1.8 V to 5.5 V,. SPDT/2:1 Mux Mini LFCSP. Data Sheet. ADG852. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet ADG852 Analog Devices, Revision: B
0.8 Ω CMOS, 1.8 V to 5.5 V, SPDT/2:1 Mux Mini LFCSP Data Sheet ADG852 FEATURES FUNCTIONAL BLOCK DIAGRAM 0.8 Ω typical on resistance Less than 1 Ω maximum on resistance at 85°C ADG852 1.8 V to 5.5 V single supply S1 High current carrying capability: 300 mA continuous D Rail-to-rail switching operation S2 Fast-switching times: <17 ns IN Typical power consumption: <0.1 µW 1.30 mm × 1.60 mm, 10-lead mini LFCSP NOTES
001
APPLICATIONS 1. SWITCHES SHOWN FOR A LOGIC 1 INPUT.
07461-
Cellular phones
Figure 1.
PDAs MP3 players Power routing Battery-powered systems PCMCIA cards Modems Audio and video signal routing Communication systems GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG852 is a low voltage CMOS single-pole, double-throw 1. <1 Ω over ful temperature range of −40°C to +85°C. (SPDT) switch. This device offers ultralow on resistance of less 2. Single 1.8 V to 5.5 V operation. than 1 Ω over the full temperature range. The ADG852 is fully specified for 5.5 V and 3.3 V supply operation. 3. Compatible with 1.8 V CMOS logic. Each switch conducts equally wel in both directions when on, 4. High current handling capability (300 mA continuous and has an input signal range that extends to the supplies. The current per channel). ADG852 exhibits break-before-make switching action. 5. Low THD + N: 0.08% typical. The ADG852 is available in a 1.30 mm × 1.60 mm 10-lead 6. 1.30 mm × 1.60 mm, 10-lead mini LFCSP. mini LFCSP.
Rev. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2008–2012 Analog Devices, Inc. All rights reserved.
Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Description Typical Performance Characteristics Test Circuits Terminology Outline Dimensions Ordering Guide
