Datasheet ADG852 (Analog Devices) - 8
Description | 0.8 Ω CMOS, 1.8 V to 5.5 V, SPDT/2:1 Mux Mini LFCSP |
Pages / Page | 16 / 8 — ADG852. Data Sheet. DD = 5V. A = 25°C. –10. VDD = 5V, 3.3V. –20. N (. … |
Revision | B |
File Format / Size | PDF / 205 Kb |
ADG852. Data Sheet. DD = 5V. A = 25°C. –10. VDD = 5V, 3.3V. –20. N (. –30. –40. NJE I. –50. NUAT E T. VDD = 3V. –60. CHARG. VDD = 2.5V. –70. –80. –90. 0.1. 100
ADG852 Data Sheet 70 0 V T DD = 5V A = 25°C –10 60 VDD = 5V, 3.3V –20 C) 50 p B) N ( –30 d IO 40 N ( CT –40 IO NJE I 30 –50 E NUAT E T VDD = 3V –60 AT 20 CHARG VDD = 2.5V –70 10
009
–80 0
07461-
–90 0 1 2 3 4 5 6 0.1 1 10 100 1k
012
SOURCE VOLTAGE (V) FREQUENCY (MHz)
07461- Figure 9. Charge Injection vs. Source Voltage Figure 12. Off isolation vs. Frequency
35 0 TA = 25°C –10 V 30 DD = 5V, 3.3V S1 to S2 –20 25 tON (3.3V) –30 B) ) d s –40 20 K ( tON (5V) AL –50 T IME (n S T 15 S –60 CRO 10 tOFF (5V) –70 –80 5
010
–90 tOFF (3.3V) 0
07461-
–100 –60 –40 –20 0 20 40 60 80 100 0.1 1 10 100 1k
013
TEMPERATURE (°C) FREQUENCY (MHz)
07461- Figure 10. tON/tOFF Times vs. Temperature Figure 13. Crosstalk vs. Frequency
0 0.25 –2 0.20 –4 ) VDD = 3.6V dB ( S –6 0.15 %) LOS –8 N ( VDD = 4.2V TION R HD + 0.10 –10 E T S IN V T DD = 5.5V –12 A = 25°C VDD = 5V, 3.3V 0.05 –14 –16 0 0.1 1 10 100 1k
011 014
100 1k 10k 100k FREQUENCY (MHz) FREQUENCY (Hz)
07461- 07461- Figure 11. Bandwidth Figure 14. Total Harmonic Distortion + Noise (THD+N) vs. Frequency Rev. B | Page 8 of 16 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Description Typical Performance Characteristics Test Circuits Terminology Outline Dimensions Ordering Guide
