Datasheet ADG854 (Analog Devices)
Description0.5 Ω CMOS, 1.8 V to 5.5 V, Dual SPDT/2:1 Mux, Mini LFCSP
Pages / Page16 / 1 — 0.5 Ω CMOS, 1.8 V to 5.5 V,. Dual SPDT/2:1 Mux, Mini LFCSP. ADG854. …
File Format / SizePDF / 303 Kb
0.5 Ω CMOS, 1.8 V to 5.5 V,. Dual SPDT/2:1 Mux, Mini LFCSP. ADG854. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet ADG854 Analog Devices
0.5 Ω CMOS, 1.8 V to 5.5 V, Dual SPDT/2:1 Mux, Mini LFCSP ADG854 FEATURES FUNCTIONAL BLOCK DIAGRAM 0.8 Ω typical on resistance ADG854 Less than 1 Ω maximum on resistance at 85°C S1A 1.8 V to 5.5 V single supply D1 High current carrying capability: 300 mA continuous S1B Rail-to-rail switching operation IN1 Fast-switching times: <17 ns IN2 Typical power consumption: <0.1 μW 1.30 mm × 1.60 mm mini LFCSP S2A D2 S2B
1 00
7- 08 07
Cellular phones SWITCHES SHOWN FOR PDAs A LOGIC 1 INPUT MP3 players
Figure 1.
Power routing Battery-powered systems PCMCIA cards Modems Audio and video signal routing Communication systems GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG854 is a low voltage CMOS device containing two 1. <1 Ω over full temperature range of –40°C to +85°C. independently selectable single-pole, double-throw (SPDT) 2. Single 1.8 V to 5.5 V operation. switches. This device offers ultralow on resistance of <1 Ω over the full temperature range. The ADG854 is fully specified for 3. Compatible with 1.8 V CMOS logic. 5.5 V and 3.3 V supply operation. 4. High current handling capability: 300 mA continuous Each switch conducts equally well in both directions when on current per channel. and has an input signal range that extends to the supplies. The 5. Low THD + N: 0.08% typical. ADG854 exhibits break-before-make switching action. 6. 1.30 mm × 1.60 mm mini LFCSP. The ADG854 is available in a 1.3 mm × 1.6 mm 10-lead mini LFCSP.
Rev. 0 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2008 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTION TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
