Datasheet ADG824 (Analog Devices)
Description | 0.5 Ω CMOS 1.65 V to 3.6 V Dual SPDT/2:1 Mux in Mini LFCSP Package |
Pages / Page | 16 / 1 — 0.5 Ω CMOS 1.65 V to 3.6 V Dual SPDT/2:1. Mux in Mini LFCSP Package. Data … |
Revision | C |
File Format / Size | PDF / 243 Kb |
0.5 Ω CMOS 1.65 V to 3.6 V Dual SPDT/2:1. Mux in Mini LFCSP Package. Data Sheet. ADG824. FEATURES. FUNCTIONAL BLOCK DIAGRAM
0.5 Ω CMOS 1.65 V to 3.6 V Dual SPDT/2:1 Mux in Mini LFCSP Package Data Sheet ADG824 FEATURES FUNCTIONAL BLOCK DIAGRAM 0.5 Ω typical on resistance ADG824 0.85 Ω maximum on resistance at 85°C S1A 1.65 V to 3.6 V operation D1 S1B High current carrying capability: 300 mA continuous Rail-to-rail switching operation IN1 Fast switching times: <20 ns IN2 Typical power consumption: (<0.1 µW) 1.3 mm × 1.6 mm mini LFCSP package S2A D2 APPLICATIONS S2B
001
Cellular phones SWITCHES SHOWN FOR A LOGIC 1 INPUT
06693-
PDAs
Figure 1.
MP3 players Power routing Battery-powered systems PCMCIA cards Modems Audio and video signal routing Communication systems GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG824 is a low voltage CMOS device containing two 1. <0.85 Ω over the full temperature range of –40°C to +85°C. independently selectable single-pole, double throw (SPDT) 2. Single 1.65 V to 3.6 V operation. switches. This device offers ultralow on resistance of less than 3. 0.85 Ω over the full temperature range. The ADG824 is fully 1.8 V logic compatible. specified for 3.3 V, 2.5 V, and 1.8 V supply operation. 4. High current carrying capability (300 mA continuous current at 3.3 V). Each switch conducts equally well in both directions when on, and has an input signal range that extends to the supplies. The 5. Low THD + N (0.06% typical). ADG824 exhibits break-before-make switching action. 6. 1.3 mm × 1.6 mm mini LFCSP package. The low on resistance of the ADG824 makes this device ideal for audio switching. In addition, a data rate of 180 Mbps makes the device suitable for USB low speed (1.5 Mbps) and full speed (12 Mbps) data switching. The ADG824 is available in a 1.3 mm × 1.6 mm, 10-lead mini LFCSP package.
Rev. C Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2008–2012 Analog Devices, Inc. All rights reserved.
Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Outline Dimensions Ordering Guide
