Datasheet ADG772 (Analog Devices) - 9
DescriptionCMOS Low Power Dual 2:1 Mux/Demux USB 2.0 (480 Mbps)/USB 1.1 (12 Mbps)
Pages / Page12 / 9 — Data Sheet. ADG772. TEST CIRCUITS. IDS. RON = V1/IDS. IS (OFF). ID (OFF). …
RevisionC
File Format / SizePDF / 387 Kb
Data Sheet. ADG772. TEST CIRCUITS. IDS. RON = V1/IDS. IS (OFF). ID (OFF). ID (ON). VDD. 0.1µF. S1B. 50%. S1A. OUT. VIN. 50Ω. 35pF. 90%. VOUT. GND. tON. tOFF. 80%
Data Sheet ADG772 TEST CIRCUITS IDS RON = V1/IDS IS (OFF) ID (OFF) ID (ON) VDD 0.1µF S1B 50% S1A OUT VIN 50Ω 35pF 90% VOUT GND tON tOFF 80%
Data Sheet ADG772 TEST CIRCUITS IDS V1 S D VS RON = V1/IDS
04 0 2- 69 06 Figure 21. On Resistance
IS (OFF) ID (OFF) S D A A VS VD
05 -0 92 66 0 Figure 22. Off Leakage
ID (ON) S D NC A
06
VD
-0 692 06 Figure 23. On Leakage
VDD 0.1µF VDD V S1B S V 50% 50% S1A D OUT VIN RL CL IN 50Ω 35pF 90% 90% VOUT GND
7
tON tOFF
-00 692 06 Figure 24. Switching Times, tON, tOFF
VDD 0.1µF 50% 50% V 0V DD VIN V S1B S VOUT S1A D V 80% OUT 80% RL CL IN 50Ω 35pF tBBM tBBM GND
8 0 0 2- 69 06 Figure 25. Break-Before-Make Time Delay, tBBM
VDD SWITCH ON SWITCH OFF VIN S1B NC D VS S1A VOUT IN 1nF VOUT ∆VOUT GND QINJ = CL × ∆VOUT
9 00 2- 69 06 Figure 26. Charge Injection Rev. C | Page 9 of 12 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TRUTH TABLE TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
