Datasheet FLS122 (Flusso) - 2
ManufacturerFlusso
DescriptionThe Smallest Air Velocity Sensor
Pages / Page2 / 2 — Sensing solutions. Parameter. Typical value. Type no. Packing type. Size. …
File Format / SizePDF / 324 Kb
Sensing solutions. Parameter. Typical value. Type no. Packing type. Size. Quantity. Part no. flussoltd.com
Sensing solutions Parameter Typical value Type no Packing type Size Quantity Part no flussoltd.com
Sensing solutions
Product information Features • Silicon-MEMS thermal air velocity and air flow sensor • Firmware running on a standard microcontroller delivers digital flow and airspeed sensing solutions • Fully temperature-compensated readings • Programmable operating modes and features • Fully compatible with SMD assembly processes • Easy integration into an existing flow path 6-pin DFN package 3.5 mm × 3.5 mm footprint 2 mm overall height Flow sensor specifications
Footprint 3.5 mm x 3.5 mm Air speed range up to 20 ms-1 Span accuracy ±5% m.v.* *m.v. is measured value Ordering guide
FLS122 Tape & reel 7" 500 min FLS-122-TR07 FLS122 Waffle tray 10 cm x 10 cm 1 to 324 FLS-122-WT324 For further application information or a copy of the full product datasheet please visit
flussoltd.com
FL-001908-SM, 2022-04-27
