Datasheet TCET1100, TCET1100G (Vishay) - 5
ManufacturerVishay
DescriptionOptocoupler, Phototransistor Output, High Temperature
Pages / Page9 / 5 — TCET1100, TCET1100G. SWITCHING CHARACTERISTICS PARAMETER. TEST CONDITION. …
File Format / SizePDF / 142 Kb
TCET1100, TCET1100G. SWITCHING CHARACTERISTICS PARAMETER. TEST CONDITION. SYMBOL. MIN. TYP. MAX. UNIT
TCET1100, TCET1100G SWITCHING CHARACTERISTICS PARAMETER TEST CONDITION SYMBOL MIN TYP MAX UNIT
TCET1100, TCET1100G
SWITCHING CHARACTERISTICS PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
V Delay time S = 5 V, IC = 2 mA, RL = 100 Ω, t (see Fig. 3) d - 3 - μs V Rise time S = 5 V, IC = 2 mA, RL = 100 Ω, t (see Fig. 3) r - 3 - μs V Turn-on time S = 5 V, IC = 2 mA, RL = 100 Ω, t (see Fig. 3) on - 6 - μs V Storage time S = 5 V, IC = 2 mA, RL = 100 Ω, t (see Fig. 3) s - 0.3 - μs V Fall time S = 5 V, IC = 2 mA, RL = 100 Ω, t (see Fig. 3) f - 4.7 - μs V Turn-off time S = 5 V, IC = 2 mA, RL = 100 Ω, t (see Fig. 3) off - 5 - μs V Turn-on time S = 5 V, IF = 10 mA, RL = 1 kΩ, t (see Fig. 4) on - 9 - μs V Turn-off time S = 5 V, IF = 10 mA, RL = 1 kΩ, t (see Fig. 4) off - 10 - μs I F I I + 5 V F F 0 0 IC = 2 mA; adjusted through t p t I input amplitude C 100 % R 90 % G = 50 Ω tp = 0.01 T tp = 50 µs Channel I 10 % Oscilloscope 0 t R r Channel II L = 1 MΩ t t t C d t f L = 20 pF s t t 50 Ω 100 Ω on off tp Pulse duration ts Storage time td Delay time t f Fall time t t (= t 95 10804 r Rise time off s + tf) Turn-off time ton (= td + tr) Turn-on time 96 11698 Fig. 3 - Test Circuit, Non-Saturated Operation Fig. 5 - Switching Times I I + 5 V F F = 10 mA 0 IC RG = 50 Ω t p = 0.01 T t p = 50 µs Channel I Oscilloscope R 1 MΩ Channel II L ≥ CL ≤ 20 pF 50 Ω 1 kΩ 95 10843 Fig. 4 - Test Circuit, Saturated Operation Rev. 2.4, 13-Jan-2021
5
Document Number: 83503 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
