Datasheet TCET1100, TCET1100G (Vishay)
ManufacturerVishay
DescriptionOptocoupler, Phototransistor Output, High Temperature
Pages / Page9 / 1 — TCET1100, TCET1100G. Optocoupler, Phototransistor Output, High …
File Format / SizePDF / 142 Kb
TCET1100, TCET1100G. Optocoupler, Phototransistor Output, High Temperature. FEATURES. LINKS TO ADDITIONAL RESOURCES
Datasheet TCET1100, TCET1100G Vishay
TCET1100, TCET1100G
Optocoupler, Phototransistor Output, High Temperature FEATURES
• High common mode rejection C E • Low temperature coefficient of CTR 4 3 • CTR offered in 7 groups • Reinforced isolation provides circuit protection against electrical shock (safety class II) • Isolation materials according to UL 94 V-0 1 2 A C • Pollution degree 2 (DIN / VDE 0110 / resp. IEC 60664) • Climatic classification 55 / 100 / 21 (IEC 60068 part 1) • Rated impulse voltage (transient overvoltage) 17197_4 VIOTM = 6 kVpeak • Isolation test voltage (partial discharge test voltage)
Vpd = 1.6 kV • Rated isolation voltage (RMS includes DC) V Related IOWM = 600 VRMS Documents • Rated recurring peak voltage (repetitive)
DESCRIPTION
VIORM = 848 Vpeak The TCET110. consists of a phototransistor optically • Creepage current resistance according to VDE 0303 / coupled to a gallium arsenide infrared-emitting diode in a IEC 60112 comparative tracking index: CTI ≥ 175 4-lead plastic dual inline package. • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912
AGENCY APPROVALS
• UL 1577
• cUL 1577 Circuits for safe protective separation against electrical shock according to safety class II (reinforced isolation): • DIN EN 60747-5-5 (VDE 0884-5) • For application class I to IV at mains voltage ≤ 300 V • BSI: EN 62368-1:2014 • For application class I to III at mains voltage ≤ 600 V • CQC GB4943.1-2011 according to DIN EN 60747-5-5 (VDE 0884), suitable for: • CQC GB8898-2011 - Switch-mode power supplies - Line receiver - Computer peripheral interface - Microprocessor system interface
ORDERING INFORMATION
DIP
T C E T 1 1 0 # #
PART NUMBER LEAD FORM 7.62 mm
AGENCY CTR (%) CERTIFIED / PACKAGE 10 mA UL, cUL, VDE, BSI, CQC 50 to 600 40 to 80 63 to 125 100 to 200 160 to 320 100 to 300 80 to 160 130 to 260 200 to 400
DIP-4 TCET1100 - TCET1102 TCET1103 - TCET1106 TCET1107 TCET1108 TCET1109 DIP-4, 400 mil TCET1100G TCET1101G TCET1102G TCET1103G TCET1104G TCET1106G TCET1107G TCET1108G TCET1109G
Note
• G = lead form 10.16 mm; G is not marked on the body Rev. 2.4, 13-Jan-2021
1
Document Number: 83503 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
