Datasheet MAX4210, MAX4211 (Maxim) - 6
ManufacturerMaxim
DescriptionHigh-Side Power and Current Monitors
Pages / Page32 / 6 — High-Side Power and Current Monitors. ELECTRICAL CHARACTERISTICS …
File Format / SizePDF / 687 Kb
High-Side Power and Current Monitors. ELECTRICAL CHARACTERISTICS (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
High-Side Power and Current Monitors ELECTRICAL CHARACTERISTICS (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
(VCC = 5.0V, VRS+ = 25V, VSENSE = 5mV, VIN = 1.0V, VLE = 0V, RIOUT = RPOUT = 1MΩ, VCIN1+ = VCIN2+ = VREF, VCIN1- = VCIN2- = GND, VINHIBIT = 0V, RCOUT1 = RCOUT2 = 5kΩ connected to VCC, TA = -40°C to +85°C, unless otherwise noted. Typical values are at TA = +25°C, unless otherwise noted.) (Note 1)
VSENSE = 5mV to TA = +25°C ±0.15 ±1.5 ∆VPOUT_MAX/ 100mV, VRS+ = 5V to % FS O* FSO 25V TA = TMIN to TMAX ±3.0 V TA = +25 SENSE = 150mV, °C ±0.2 ±1.5 Total POUT Output Error VRS+ > 15V TA = TMIN to TMAX ±3.0 (Note 10) ∆V V POUT_MAX/ SENSE = 100mV, VRS+ > 4V ±2.5 % VPOUT VSENSE = 100mV, VRS+ > 9V ±1.2 VSENSE = 50mV, VRS+ > 6V ±1.8 VSENSE = 25mV, VRS+ > 15V ±1.8 POUT Output Offset Voltage V T SENSE = 0V, A = +25°C 2 6.5 mV (Note 11) V
MAX4210/MAX4211
RS+ = 25V TA = TMIN to TMAX 20
MAX4210C/MAX4211C (power gain = 1.64)
TA = +25°C ±0.5 ±1.5 ∆VPOUT/ VSENSE = 10mV to ∆VSENSE 100mV, VRS+ = 25V T POUT Gain Accuracy A = TMIN to TMAX ±3.0 % (Note 9) TA = +25 V °C ±0.5 ±1.5 ∆VPOUT/ SENSE = 100mV, ∆VRS+ VRS+ = 5V to 25V TA = TMIN to TMAX ±3.0 VSENSE = 5mV to TA = +25°C ±0.15 ±1.5 ∆VPOUT_MAX/ 100mV, VRS+ = 5V % FS O* FSO to 25V TA = TMIN to TMAX ±3.0 Total POUT Output Error VSENSE = 100mV, VRS+ ≥ 4V ±2.5 (Note 10) V ∆V SENSE = 100mV, VRS+ POUT_MAX/ ≥ 9V ±1.2 % VPOUT VSENSE = 50mV, VRS+ ≥ 6V ±1.8 VSENSE = 25mV, VRS+ ≥ 15V ±1.8 POUT Output Offset Voltage V T SENSE = 0V, A = +25°C 3 10 mV (Note 11) VRS+ = 25V TA = TMIN to TMAX 30
MAX4210D/MAX4211D (power gain = 16.67)
TA = +25°C ±0.5 ±1.5 ∆VPOUT/ VSENSE = 10mV to ∆VSENSE 100mV, VIN = 1V T POUT Gain Accuracy A = TMIN to TMAX ±3.0 % (Note 9) TA = +25 V °C ±0.5 ±1.5 ∆VPOUT/ SENSE = 100mV, ∆VIN VIN = 0.2V to 1V TA = TMIN to TMAX ±3.0 *FSO refers to full-scale output under the conditions: VSENSE = 100mV, VRS+ = +25V, or VIN = 1V.
6 _______________________________________________________________________________________
