Datasheet MAX4210, MAX4211 (Maxim) - 7
Manufacturer | Maxim |
Description | High-Side Power and Current Monitors |
Pages / Page | 32 / 7 — High-Side Power and. Current Monitors. MAX4210/MAX4211. ELECTRICAL … |
File Format / Size | PDF / 687 Kb |
High-Side Power and. Current Monitors. MAX4210/MAX4211. ELECTRICAL CHARACTERISTICS (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP
High-Side Power and Current Monitors MAX4210/MAX4211 ELECTRICAL CHARACTERISTICS (continued)
(VCC = 5.0V, VRS+ = 25V, VSENSE = 5mV, VIN = 1.0V, VLE = 0V, RIOUT = RPOUT = 1MΩ, VCIN1+ = VCIN2+ = VREF, VCIN1- = VCIN2- = GND, VINHIBIT = 0V, RCOUT1 = RCOUT2 = 5kΩ connected to VCC, TA = -40°C to +85°C, unless otherwise noted. Typical values are at TA = +25°C, unless otherwise noted.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
VSENSE = 5mV to TA = +25°C ±0.15 ±1.5 ∆VPOUT_MAX/ 100mV, VRS+ = 25V, % FS O* FSO VIN = 0.2V to 1V TA = TMIN to TMAX ±3.0 V TA = +25 SENSE = 150mV, VRS+ °C ±0.2 ±1.5 = 25V, VIN = 600mV TA = TMIN to TMAX ±3.0 VSENSE = 100mV, VRS+ = 15V, Total POUT Output Error ±2.5 VIN ≥ 160mV (Note 10) ∆VPOUT_MAX/ VSENSE = 100mV, VRS+ = 15V, ±1.2 % VPOUT VIN ≥ 360mV VSENSE = 50mV, VRS+ = 15V, ±1.8 VIN ≥ 240mV VSENSE = 25mV, VRS+ = 15V, ±1.8 VIN ≥ 600mV POUT Output Offset Voltage V TA = +25 SENSE = 0V, °C 1.5 5 mV (Note 11) VRS+ = 25V, VIN = 1V TA = TMIN to TMAX 15
MAX4210E/MAX4211E (power gain = 25.00)
V TA = +25 SENSE = 10mV to °C ±0.5 ±1.5 ∆VPOUT/ POUT Gain Accuracy ∆VSENSE 100mV, VIN = 1V TA = TMIN to TMAX ±3.0 % (Note 9) V T ∆V A = +25 POUT/ SENSE = 100mV, °C ±0.5 ±1.5 ∆VIN VIN = 0.2V to 1V TA = TMIN to TMAX ±3.0 VSENSE = 5mV to TA = +25°C ±0.15 ±1.5 ∆VPOUT_MAX/ 100mV, VRS+ = 25V, % FS O* FSO VIN = 0.2V to 1V TA = TMIN to TMAX ±3.0 VSENSE = 150mV, TA = +25°C ±0.2 ±1.5 VRS+ =25V, VIN = 600mV TA = TMIN to TMAX ±3.0 Total POUT Output Error VSENSE = 100mV, VRS+ = 15V, ±2.5 (Note 10) VIN ≥ 160mV ∆VPOUT_MAX/ VSENSE = 100mV, VRS+ = 15V, % VPOUT ±1.2 VIN ≥ 360mV VSENSE = 50mV, VRS+ = 15V, ±1.8 VIN ≥ 240mV VSENSE = 25mV, VRS+ = 15V, ±1.8 VIN ≥ 600mV POUT Output Offset Voltage V TA = +25 SENSE = 0V, °C 2 6.5 mV (Note 11) VRS+ = 25V, VIN = 1V TA = TMIN to TMAX 20 *FSO refers to full-scale output under the conditions: VSENSE = 100mV, VRS+ = +25V, or VIN = 1V.
_______________________________________________________________________________________ 7
