Datasheet EL5100, EL5101, EL5300 (Renesas) - 4
ManufacturerRenesas
Description200MHz Slew Enhanced VFA
Pages / Page15 / 4 — Absolute Maximum Ratings. Thermal Information. DC Electrical …
File Format / SizePDF / 767 Kb
Absolute Maximum Ratings. Thermal Information. DC Electrical Specifications. PARAMETER. DESCRIPTION. CONDITIONS. MIN. TYP. MAX. UNIT
Absolute Maximum Ratings Thermal Information DC Electrical Specifications PARAMETER DESCRIPTION CONDITIONS MIN TYP MAX UNIT
(TA = +25°C)
Thermal Information
Supply Voltage between VS+ and VS-. 13.2V Storage Temperature Range . .-65°C to +150°C Input Voltage . .±VS Ambient Operating Temperature Range . .-40°C to +85°C Differential Input Voltage . .±4V Operating Junction Temperature . +150°C Maximum Output Current. 80mA Pb-free reflow profile . .see link below Maximum Slewrate from VS+ to VS- . 1V/µs http://www.intersil.com/pbfree/Pb-FreeReflow.asp CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. IMPORTANT NOTE: All parameters having Min/Max specifications are guaranteed. Typical values are for information purposes only. Unless otherwise noted, all tests are at the specified temperature and are pulsed tests, therefore: TJ = TC = TA
VS = ±5V, GND = 0V, TA = +25°C, VCM = 0V, VOUT = 0V, VENABLE = GND or OPEN, Unless Otherwise Specified.
VOS Offset Voltage -4 1 4 mV TCVOS Offset Voltage Temperature Coefficient Measured from TMIN to TMAX 8 µV/°C IB Input Bias Current VIN = 0V -6 2 6 µA IOS Input Offset Current VIN = 0V -2.5 0.5 2.5 µA TCIOS Input Bias Current Temperature Measured from TMIN to TMAX 8 nA/°C Coefficient PSRR Power Supply Rejection Ratio 70 90 dB CMRR Common Mode Rejection Ratio VCM from -3V to +3V 60 75 dB CMIR Common Mode Input Range Guaranteed by CMRR test -3 +3 V RIN Input Resistance VIN = -3V to +3V 0.7 1.2 M CIN Input Capacitance 1 pF IS,ON Supply Current - Enabled Per amplifier 2.1 2.5 2.9 mA IS,OFF Supply Current - Shut Down VS+, per amplifier -5 0 5 µA VS-, per amplifier 5 17 25 µA PSOR Power Supply Operating Range 3.3 12 V AVOL Open Loop Gain RL = 1k to GND, VOUT from -2.5V to +2.5V 55 60 dB VOP Positive Output Voltage Swing RL = 150 to GND 3.2 3.4 V RL = 1k to GND 3.6 3.8 V VON Negative Output Voltage Swing RL = 150 to GND -3.4 -3.2 V RL = 1k to GND -3.8 -3.6 V IOUT Output Current RL = 10 to 0V ±60 ±100 mA VIH-EN ENABLE pin Voltage for Power Up VS+ -4 V VIL-EN ENABLE pin Voltage for Shut Down VS+ -1 V IEN Enable Pin Current Enabled, VEN = 0V -1 1 µA Disabled, VEN = 5V 5 17 25 µA FN7330 Rev 3.00 Page 4 of 15 May 3, 2007
