Datasheet EL5100, EL5101, EL5300 (Renesas) - 5
ManufacturerRenesas
Description200MHz Slew Enhanced VFA
Pages / Page15 / 5 — Closed Loop AC Electrical Specifications. PARAMETER. DESCRIPTION. …
File Format / SizePDF / 767 Kb
Closed Loop AC Electrical Specifications. PARAMETER. DESCRIPTION. CONDITIONS. MIN. TYP. MAX. UNIT. Typical Performance Curves. 8.8pF. V=+1
Closed Loop AC Electrical Specifications PARAMETER DESCRIPTION CONDITIONS MIN TYP MAX UNIT Typical Performance Curves 8.8pF V=+1
VS =
5V, TA = 25°C, VENABLE = 0V, AV = +1, RF = 0, RL = 150 to GND, unless otherwise specified.
BW -3dB Bandwidth (VOUT = 200mVP-P) VS = ±5V, AV = 1, RF = 0 150 200 MHz SR Slew Rate RL = 100, VOUT = -3V to +3V, AV = +2 1500 2200 4500 V/µs tR,tF Rise Time, Fall Time ±0.1V step 2.8 ns OS Overshoot ±0.1V step 10 % tPD Propagation Delay ±0.1V step 3.2 ns tS 0.1% Settling Time VS = ±5V, RL = 500, AV = 1, VOUT = ±2.5V 20 ns dG Differential Gain AV = 2, RL = 150, VINDC = -1 to +1V 0.08 % dP Differential Phase AV = 2, RL = 150, VINDC = -1 to +1V 0.1 ° eN Input Noise Voltage f = 10kHz 10 nV/Hz iN Input Noise Current f = 10kHz 7 pA/Hz tDIS Disable Time 180 ns tEN Enable Time 650 ns
Typical Performance Curves 5 5 A A 8.8pF 4 V=+1 4 V=+1 RL=50 ±1.75 RL=500 6.6pF 3 SUPPLY=±5.0V B) 3 CIN-=0pF ±2.0 d SUPPLY=±5.0V 4.4pF 2 2 ±3.0 ±4.0 2.2pF AIN ( 1 ±5.0 1 GAIN (dB) G 0pF D 0 0 -1 -1 ALIZE -2 RM -2 -3 NORMALIZED -3 NO -4 -4 -5 -5 100K 1M 10M 100M 1G 100K 1M 10M 100M 1G FREQUENCY (Hz) FREQUENCY (Hz) FIGURE 1. GAIN vs FREQUENCY FOR VARIOUS CL FIGURE 2. GAIN vs FREQUENCY FOR VARIOUS CL 5 5 A 17.1pF A 6.6pF 4 V=+2 V=+2 R 4 L=150 RF=RG=383 3 C 11.5pF 4.4pF L=2.2pF 3 CL=2.2pF (dB) R (dB) R 2 F=383 L=150 5.8pF 2 2.2pF 1 GAIN 1 D GAIN 0 D 0 0pF -1 ALIZE -1 ALIZE -2 2.2pF -2 NORM -3 -3 NORM -4 -4 -5 -5 100K 1M 10M 100M 600M 100K 1M 10M 100M 600M FREQUENCY (Hz) FREQUENCY (Hz) FIGURE 3. GAIN vs FREQUENCY FOR VARIOUS CIN- FIGURE 4. GAIN vs FREQUENCY FOR VARIOUS CIN-
FN7330 Rev 3.00 Page 5 of 15 May 3, 2007
