Datasheet PLE (Nichicon)
ManufacturerNichicon
DescriptionCONDUCTIVE POLYMER ALUMINUM SOLID ELECTROLYTIC CAPACITORS
Pages / Page2 / 1 — CONDUCTIVE POLYMER ALUMINUM SOLID ELECTROLYTIC CAPACITORS. PLE. PLF
Datasheet PLE Nichicon
CONDUCTIVE POLYMER ALUMINUM SOLID ELECTROLYTIC CAPACITORS CONDUCTIVE POLYMER ALUMINUM SOLID ELECTROLYTIC CAPACITORS PLE
Radial Lead Type, Ultra-low ESR
PLE
Dimensions Ultra-low ESR, High ripple current. Leakage Current Load life of 2000 hours at 105°C. Rated Voltage ESR Rated Ripple Surge Voltage Rated Capacitance Case Size (µA) Radial lead type : (V) tan (m (mArms) (V) δ Ω) (µF) Part Number Code φD × L (mm) at 20°C after ( ) (20°C/100kHz) (105°C/100kHz) Lead free flow soldering condition correspondence 2 minutes Compliant to the RoHS directive (2011/65/EU,(EU)2015/863). 560 8 × 9 0.08 280 5 6100 PLE0E561MCO1
PLF
Low ESR
PLE
820 8 × 9 0.08 410 5 6300 PLE0E821MCO6 2.5 (0E) 2.8 820 8 × 12 0.08 410 5 6600 PLE0E821MDO1 Specifications 1000 10 × 13 0.08 500 5 7100 PLE0E102MDO1 Item Performance Characteristics 1500 10 × 13 0.08 750 5 7300 PLE0E152MDO1 Category Temperature Range –55 to +105°C 560 8 × 9 0.08 448 5 6000 PLE0G561MCO1 Rated Voltage Range 2.5 to 6.3V 4 680 8 × 12 0.08 544 5 6500 PLE0G681MDO1 Rated Capacitance Range 470 to 1500µF 4.6 (0G) 820 10 × 13 0.08 656 5 7000 PLE0G821MDO1 Capacitance Tolerance ± 20% at 120Hz, 20°C 1200 10 × 13 0.08 960 5 7200 PLE0G122MDO1 Tangent of loss angle (tan δ) Less than or equal to the specified value at 120Hz, 20°C ESR ( 1) Less than or equal to the specified value at 100kHz, 20°C 470 8 × 12 0.08 592 5 6400 PLE0J471MDO1 6.3 Leakage Current ( 2) Less than or equal to the specified value. After 2 minutes' application of rated voltage at 20°C (0J) 7.2 680 10 × 13 0.08 857 5 6700 PLE0J681MDO1 Temperature Characteristics Z+105°C / Z+20°C 1.25 (100kHz) 820 10 × 13 0.08 1033 5 6800 PLE0J821MDO1 (Max.Impedance Ratio) Z–55°C / Z+20°C 1.25 No marked, 1 will be put at 12th digit of type numbering system. Capacitance change Within ± 20% of the initial capacitance value ( 3) : In this case, 6 will be put at 12th digit of type numbering system. The specifications listed at right shall be met when the tan δ 150% or less than the initial specified value Endurance capacitors are restored to 20°C after the rated voltage is ESR ( 1) 150% or less than the initial specified value applied for 2000 hours at 105°C. For formed lead or taped product specifications and minimum order quantity, Leakage current ( 2) Less than or equal to the initial specified value please refer to the Guidelines for Aluminum Electrolytic Capacitors. Capacitance change Within ± 20% of the initial capacitance value ( 3) Damp Heat The specifications listed at right shall be met when the tan 150% or less than the initial specified value capacitors are restored to 20°C after the rated voltage is δ (Steady State) ESR ( 1) 150% or less than the initial specified value applied for 1000 hours at 60°C, 90% RH. Leakage current ( 2) Less than or equal to the initial specified value After soldering the capacitor under the soldering conditions prescribed Capacitance change Within ± 10% of the initial capacitance value ( 3) 130% or less than the initial specified value Resistance to here as preheat at 150 to 200°C for 60 to 180 seconds and peak tan δ temperature at 265°C for 10 seconds or less, the capacitor shall meet ESR ( 1) 130% or less than the initial specified value Soldering Heat the specifications listed at right, provided that its temperature profile is Leakage current ( 2) Less than or equal to the initial specified value measured at both of terminal ends facing the soldering side. Marking Navy blue print on the case top 1 ESR should be measured at both of the terminal ends closest to the capacitor body. 2 Conditioning : If any doubt arises, measure the leakage current after the voltage treatment of applying DC rated voltage continuously to the capacitor for 120 minutes at 105°C. 3 Initial value : The value before test of examination of resistance to soldering. Dimensions Type numbering system (Example : 4V 560µF) 1 2 3 4 5 6 7 8 9 10 11 12 Capacitance Resin coated Case Voltage(g:4V) P L E 0 G 5 6 1 M C O 1 Size code ±0.5 LE 560 g 841 D±0.5 φ P Configuration Capacitance tolerance (±20%) φd Series Lot. No. Rated capacitance (560µF) L+0.5MAX. 15MIN 4MIN Rated voltage (4V) Series name (mm) Type Size φ8 × 9L φ8 × 12L φ10 × 13L φD 8.0 8.0 10.0 Voltage L 8.5 11.5 12.5 Frequency coefficient of rated ripple current V 2.5 4 6.3 P 3.5 3.5 5.0 0 Frequency0/ 120Hz 1kHz 10kHz 100kHz or more Code e g j φd 0.6 0.6 0.6 Coefficient 0.05 0.30 0.70 1.00 Please refer to the Guidelines for Aluminum Electrolytic Capacitors for end seal configuration information. Dimension table in next page. CAT.8100K
