Datasheet PLE (Nichicon) - 2
ManufacturerNichicon
DescriptionCONDUCTIVE POLYMER ALUMINUM SOLID ELECTROLYTIC CAPACITORS
Pages / Page2 / 2 — CONDUCTIVE POLYMER ALUMINUM SOLID ELECTROLYTIC CAPACITORS. PLE. PLF
CONDUCTIVE POLYMER ALUMINUM SOLID ELECTROLYTIC CAPACITORS PLE PLF
CONDUCTIVE POLYMER ALUMINUM SOLID ELECTROLYTIC CAPACITORS CONDUCTIVE POLYMER ALUMINUM SOLID ELECTROLYTIC CAPACITORS PLE
Radial Lead Type, Ultra-low ESR
PLE
Dimensions Ultra-low ESR, High ripple current. Leakage Current Load life of 2000 hours at 105°C. Rated Voltage ESR Rated Ripple Surge Voltage Rated Capacitance Case Size (µA) Radial lead type : (V) tan (m (mArms) (V) δ Ω) (µF) Part Number Code φD × L (mm) at 20°C after ( ) (20°C/100kHz) (105°C/100kHz) Lead free flow soldering condition correspondence 2 minutes Compliant to the RoHS directive (2011/65/EU,(EU)2015/863). 560 8 × 9 0.08 280 5 6100 PLE0E561MCO1
PLF
Low ESR
PLE
820 8 × 9 0.08 410 5 6300 PLE0E821MCO6 2.5 (0E) 2.8 820 8 × 12 0.08 410 5 6600 PLE0E821MDO1 Specifications 1000 10 × 13 0.08 500 5 7100 PLE0E102MDO1 Item Performance Characteristics 1500 10 × 13 0.08 750 5 7300 PLE0E152MDO1 Category Temperature Range –55 to +105°C 560 8 × 9 0.08 448 5 6000 PLE0G561MCO1 Rated Voltage Range 2.5 to 6.3V 4 680 8 × 12 0.08 544 5 6500 PLE0G681MDO1 Rated Capacitance Range 470 to 1500µF 4.6 (0G) 820 10 × 13 0.08 656 5 7000 PLE0G821MDO1 Capacitance Tolerance ± 20% at 120Hz, 20°C 1200 10 × 13 0.08 960 5 7200 PLE0G122MDO1 Tangent of loss angle (tan δ) Less than or equal to the specified value at 120Hz, 20°C ESR ( 1) Less than or equal to the specified value at 100kHz, 20°C 470 8 × 12 0.08 592 5 6400 PLE0J471MDO1 6.3 Leakage Current ( 2) Less than or equal to the specified value. After 2 minutes' application of rated voltage at 20°C (0J) 7.2 680 10 × 13 0.08 857 5 6700 PLE0J681MDO1 Temperature Characteristics Z+105°C / Z+20°C 1.25 (100kHz) 820 10 × 13 0.08 1033 5 6800 PLE0J821MDO1 (Max.Impedance Ratio) Z–55°C / Z+20°C 1.25 No marked, 1 will be put at 12th digit of type numbering system. Capacitance change Within ± 20% of the initial capacitance value ( 3) : In this case, 6 will be put at 12th digit of type numbering system. The specifications listed at right shall be met when the tan δ 150% or less than the initial specified value Endurance capacitors are restored to 20°C after the rated voltage is ESR ( 1) 150% or less than the initial specified value applied for 2000 hours at 105°C. For formed lead or taped product specifications and minimum order quantity, Leakage current ( 2) Less than or equal to the initial specified value please refer to the Guidelines for Aluminum Electrolytic Capacitors. Capacitance change Within ± 20% of the initial capacitance value ( 3) Damp Heat The specifications listed at right shall be met when the tan 150% or less than the initial specified value capacitors are restored to 20°C after the rated voltage is δ (Steady State) ESR ( 1) 150% or less than the initial specified value applied for 1000 hours at 60°C, 90% RH. Leakage current ( 2) Less than or equal to the initial specified value After soldering the capacitor under the soldering conditions prescribed Capacitance change Within ± 10% of the initial capacitance value ( 3) 130% or less than the initial specified value Resistance to here as preheat at 150 to 200°C for 60 to 180 seconds and peak tan δ temperature at 265°C for 10 seconds or less, the capacitor shall meet ESR ( 1) 130% or less than the initial specified value Soldering Heat the specifications listed at right, provided that its temperature profile is Leakage current ( 2) Less than or equal to the initial specified value measured at both of terminal ends facing the soldering side. Marking Navy blue print on the case top 1 ESR should be measured at both of the terminal ends closest to the capacitor body. 2 Conditioning : If any doubt arises, measure the leakage current after the voltage treatment of applying DC rated voltage continuously to the capacitor for 120 minutes at 105°C. 3 Initial value : The value before test of examination of resistance to soldering. Dimensions Type numbering system (Example : 4V 560µF) 1 2 3 4 5 6 7 8 9 10 11 12 Capacitance Resin coated Case Voltage(g:4V) P L E 0 G 5 6 1 M C O 1 Size code ±0.5 LE 560 g 841 D±0.5 φ P Configuration Capacitance tolerance (±20%) φd Series Lot. No. Rated capacitance (560µF) L+0.5MAX. 15MIN 4MIN Rated voltage (4V) Series name (mm) Type Size φ8 × 9L φ8 × 12L φ10 × 13L φD 8.0 8.0 10.0 Voltage L 8.5 11.5 12.5 Frequency coefficient of rated ripple current V 2.5 4 6.3 P 3.5 3.5 5.0 0 Frequency0/ 120Hz 1kHz 10kHz 100kHz or more Code e g j φd 0.6 0.6 0.6 Coefficient 0.05 0.30 0.70 1.00 Please refer to the Guidelines for Aluminum Electrolytic Capacitors for end seal configuration information. Dimension table in next page. CAT.8100K
