Datasheet STTH1L06 (STMicroelectronics) - 4
Manufacturer | STMicroelectronics |
Description | Turbo 2 ultrafast high voltage rectifier |
Pages / Page | 9 / 4 — Characteristics. STTH1L06. Figure 5. Relative variation of thermal. … |
File Format / Size | PDF / 112 Kb |
Characteristics. STTH1L06. Figure 5. Relative variation of thermal. Figure 6. Peak reverse recovery current
Characteristics STTH1L06 Figure 5. Relative variation of thermal Figure 6. Peak reverse recovery current impedance junction ambient versus versus dIF/dt (90% confidence) pulse duration (epoxy FR4) Zth(j-a)/Rth(j-a) IRM(A) 1.0 2.5 SMA
VR=400V
0.9 2.3
Tj=125°C IF=2 x IF(av) IF=2 x IF(a
0.8 2.0
IF=IF(av) IF=IF(a
0.7 1.8
IF=0.5 x IF(av) IF=0.5 x IF(a
0.6
δ = 0.5
1.5 0.5 1.3
IF=0.25 x IF(av) IF=0.25 x IF(a
0.4 1.0
δ = 0.2
0.3 0.8
T δ = 0.1
0.2 0.5 0.1 0.3 tp(s) dIF/dt(A/µs)
Single pulse δ=tp/T tp
0.0 0.0 1.E-01 1.E+00 1.E+01 1.E+02 1.E+03 0 5 10 15 20 25 30 35 40 45 50 Figure 7. Reverse recovery time versus dIF/dt Figure 8. Reverse recovery charges versus (90% confidence) dIF/dt (90% confidence) trr(ns) Qrr(nC) 800 220
VR=400V VR=400V
200 700
Tj=125°C Tj=125°C IF=2 x IF(av)
180 600 160
IF=IF(av)
500 140
IF=2 x IF(av) IF=2 x IF(a IF=0.5 x IF(av)
120
IF=IF(av) IF=IF(a
400
100 300 80 60 200 40 100 dIF/dt(A/µs) 20 dIF/dt(A/µs) 0 0 0 5 10 15 20 25 30 35 40 45 50 0 5 10 15 20 25 30 35 40 45 50 Figure 9. Softness factor versus dIF/dt Figure 10. Relative variations of dynamic (typical values) parameters versus junction temperature S factor 1.25 2.0
S factor
1.8 1.00 1.6 1.4
IRM
0.75 1.2
QRR
1.0 0.50 0.8 0.6 0.25 0.4
IF=IF(av) IF=IF(av)
Tj(°C)
VR=400V
0.2
Reference: Tj=125°C
dIF/dt(A/µs)
VR=400V Tj=125°C
0.00 0.0 25 50 75 100 125 0 5 10 15 20 25 30 35 40 45 50
4/9 Doc ID 8321 Rev 4 Document Outline Table 1. Device summary 1 Characteristics Table 2. Absolute ratings (limiting values) Table 3. Thermal parameters Table 4. Static electrical characteristics Table 5. Dynamic characteristics Figure 1. Conduction losses versus average current Figure 2. Forward voltage drop versus forward current Figure 3. Relative variation of thermal impedance junction ambient versus pulse duration Figure 4. Relative variation of thermal impedance junction ambient versus pulse duration Figure 5. Relative variation of thermal impedance junction ambient versus pulse duration (epoxy FR4) Figure 6. Peak reverse recovery current versus dIF/dt (90% confidence) Figure 7. Reverse recovery time versus dIF/dt (90% confidence) Figure 8. Reverse recovery charges versus dIF/dt (90% confidence) Figure 9. Softness factor versus dIF/dt (typical values) Figure 10. Relative variations of dynamic parameters versus junction temperature Figure 11. Transient peak forward voltage versus dIF/dt (90% confidence) Figure 12. Forward recovery time versus dIF/dt (90% confidence) Figure 13. Junction capacitance versus reverse voltage applied (typical values) Figure 14. Thermal resistance junction to ambient versus copper surface under each lead Figure 15. Thermal resistance junction to ambient versus copper surface under each lead (Epoxy printed circuit board FR4, copper thickness: 35 µm) 2 Package information Table 6. SMA dimensions Figure 16. Footprint (dimensions in mm) Table 7. SMB dimensions Figure 17. Footprint (dimensions in mm) Table 8. DO-41 (plastic) dimensions 3 Ordering information Table 9. Ordering information 4 Revision history Table 10. Document revision history
