Datasheet TMP35, TMP36, TMP37 (Analog Devices) - 3
DescriptionLow Voltage Temperature Sensors
Pages / Page19 / 3 — Data Sheet. TMP35/TMP36/TMP37. SPECIFICATIONS. Table 1. Parameter1. …
File Format / SizePDF / 456 Kb
Data Sheet. TMP35/TMP36/TMP37. SPECIFICATIONS. Table 1. Parameter1. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet TMP35/TMP36/TMP37 SPECIFICATIONS Table 1 Parameter1 Symbol Test Conditions/Comments Min Typ Max Unit
VS = 2.7 V to 5.5 V, −40°C ≤ TA ≤ +125°C, unless otherwise noted.
Table 1. Parameter1 Symbol Test Conditions/Comments Min Typ Max Unit
ACCURACY TMP35/TMP36/TMP37 (F Grade) TA = 25°C ±1 ±2 °C TMP35/TMP36/TMP37 (G Grade) TA = 25°C ±1 ±3 °C TMP35/TMP36/TMP37 (F Grade) Over rated temperature ±2 ±3 °C TMP35/TMP36/TMP37 (G Grade) Over rated temperature ±2 ±4 °C Scale Factor, TMP35 10°C ≤ TA ≤ 125°C 10 mV/°C Scale Factor, TMP36 −40°C ≤ TA ≤ +125°C 10 mV/°C Scale Factor, TMP37 5°C ≤ TA ≤ 85°C 20 mV/°C 5°C ≤ TA ≤ 100°C 20 mV/°C 3.0 V ≤ VS ≤ 5.5 V Load Regulation 0 µA ≤ IL ≤ 50 µA −40°C ≤ TA ≤ +105°C 6 20 m°C/µA −105°C ≤ TA ≤ +125°C 25 60 m°C/µA Power Supply Rejection Ratio PSRR TA = 25°C 30 100 m°C/V 3.0 V ≤ VS ≤ 5.5 V 50 m°C/V Linearity 0.5 °C Long-Term Stability TA = 150°C for 1000 hours 0.4 °C SHUTDOWN Logic High Input Voltage VIH VS = 2.7 V 1.8 V Logic Low Input Voltage VIL VS = 5.5 V 400 mV OUTPUT TMP35 Output Voltage TA = 25°C 250 mV TMP36 Output Voltage TA = 25°C 750 mV TMP37 Output Voltage TA = 25°C 500 mV Output Voltage Range 100 2000 mV Output Load Current IL 0 50 µA Short-Circuit Current ISC Note 2 250 µA Capacitive Load Driving CL No oscillations
2
1000 10000 pF Device Turn-On Time Output within ±1°C, 100 kΩ||100 pF load2 0.5 1 ms POWER SUPPLY Supply Range VS 2.7 5.5 V Supply Current ISY (ON) Unloaded 50 µA Supply Current (Shutdown) ISY (OFF) Unloaded 0.01 0.5 µA 1 Does not consider errors caused by self-heating. 2 Guaranteed but not tested. Rev. H | Page 3 of 19
