Datasheet Si1308EDL (Vishay) - 5
ManufacturerVishay
DescriptionN-Channel 30 V (D-S) MOSFET
Pages / Page11 / 5 — Si1308EDL. TYPICAL CHARACTERISTICS. Current Derating*. Power, …
File Format / SizePDF / 260 Kb
Si1308EDL. TYPICAL CHARACTERISTICS. Current Derating*. Power, Junction-to-Case. Power, Junction-to-Ambient
Si1308EDL TYPICAL CHARACTERISTICS Current Derating* Power, Junction-to-Case Power, Junction-to-Ambient
Si1308EDL
(25 °C, unless otherwise noted) 1.8 1.35 ) (A rrent u 0.9 C n rai D - I D 0.45 0 0 25 50 75 100 125 150 T - Case Temperature (°C) C
Current Derating*
0.6 0.45 0.5 0.36 0.4 0.27 0.3 Power (W) Power (W) 0.18 0.2 0.09 0.1 0.0 0.00 0 25 50 75 100 125 150 0 25 50 75 100 125 150 T - Case Temperature (°C) T - Ambient Temperature (°C) C A
* The power dissipation PD is based on TJ (max.) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package limit. S14-1997-Rev. C, 06-Oct-14
5
Document Number: 63399 For technical questions, contact: pmostechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
