Datasheet KBU4A, KBU4B, KBU4D, KBU4G, KBU4J, KBU4K, KBU4M (Vishay)
ManufacturerVishay
DescriptionSingle-Phase Bridge Rectifier
Pages / Page4 / 1 — KBU4A, KBU4B, KBU4D, KBU4G, KBU4J, KBU4K, KBU4M. Single-Phase Bridge …
File Format / SizePDF / 85 Kb
KBU4A, KBU4B, KBU4D, KBU4G, KBU4J, KBU4K, KBU4M. Single-Phase Bridge Rectifier. FEATURES. Case Style KBU
Datasheet KBU4A, KBU4B, KBU4D, KBU4G, KBU4J, KBU4K, KBU4M Vishay
www.vishay.com Vishay General Semiconductor
Single-Phase Bridge Rectifier FEATURES
• UL recognition, file number E54214 • Ideal for printed circuit boards • High surge current capability e4 • Plastic-passivated junction • High case dielectric strength of 1500 VRMS ~ ~
Case Style KBU
• Solder dip 275 °C max. 10 s, per JESD 22-B106 ~ ~ • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912
LINKS TO ADDITIONAL RESOURCES TYPICAL APPLICATIONS
General purpose use in AC/DC bridge full wave rectification
D 3 3 D
for monitor, TV, printer, SMPS, adapter, audio equipment, 3D Models and home appliances applications.
MECHANICAL DATA PRIMARY CHARACTERISTICS Case:
KBU Package KBU Molding compound meets UL 94 V-0 flammability rating IF(AV) 4 A Base P/N-E4 - RoHS-compliant, commercial grade 50 V, 100 V, 200 V, 400 V, 600 V, VRRM 800 V, 1000 V
Terminals:
silver plated leads, solderable per I J-STD-002 and JESD22-B102 FSM 200 A IR 5 μA
Polarity:
as marked on body VF at IF = 4 A 1.0 V
Mounting Torque:
10 cm-kg (8.8 inches-lbs) max. TJ max. 150 °C
Recommended Torque:
5.7 cm-kg (5 inches-lbs) Circuit configuration In-line
MAXIMUM RATINGS
(TA = 25 °C unless otherwise noted)
PARAMETER SYMBOL KBU4A KBU4B KBU4D KBU4G KBU4J KBU4K KBU4M UNIT
Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 400 600 800 1000 V Maximum average forward TC = 100 °C (1) 4.0 I A rectified output current at F(AV) TA = 30 °C (2) 4.0 Peak forward surge current single sine-wave I superimposed on rated load FSM 200 A Operating junction and storage temperature range TJ, TSTG -50 to +150 °C
Notes
(1) Units mounted on a 2.0" x 1.6" x 0.3" thick (5 cm x 4 cm x 0.8 cm) aluminum plate (2) Units mounted on PCB with 0.5" x 0.5" (12 mm x 12 mm) copper pads and 0.375" (9.5 mm) lead length
ELECTRICAL CHARACTERISTICS
PARAMETER TEST CONDITIONS SYMBOL KBU4A KBU4B KBU4D KBU4G KBU4J KBU4K KBU4M UNIT
Maximum instantaneous I forward drop per diode F = 4.0 A VF 1.0 V Maximum DC reverse TA = 25 °C 5.0 μA current at rated DC blocking IR voltage per diode TA = 125 °C 1.0 mA Revision: 14-Apr-2020
1
Document Number: 88656 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
