Datasheet ADA4097-1, ADA4097-2 (Analog Devices) - 10
Description50 V, 130 kHz, 32.5 µA per Channel, Robust, Over-The-Top, Precision Op Amps
Pages / Page31 / 10 — ADA4097-1/ADA4097-2. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS
ADA4097-1/ADA4097-2 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS
Data Sheet
ADA4097-1/ADA4097-2 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS Figure 4. Pin Configuration for the ADA4097-1 6-Lead TSOT Table 6. Pin Function Descriptions for ADA4097-1 6-Lead TSOT Pin No. Mnemonic Description
1 VOUT Amplifier Output. 2 −VS Negative Power Supply. In single-supply applications, the −VS pin is normally soldered to a low impedance ground plane. In split-supply applications, bypass the −VS pin with a capacitance of at least 0.1 μF to a low impedance ground plane, as close to the −VS pin as possible. 3 +IN Noninverting Input of the Amplifier. 4 −IN Inverting Input of the Amplifier. 5 SHDN Op Amp Shutdown. The threshold for shutdown is approximately 1 V above the negative supply. If the SHDN pin is hard tied to −VS or floating, the amplifier is active. If the SHDN pin is asserted high (VSHDN > −VS + 1.5 V), the amplifier is placed in a shutdown state, and the output of the amplifier goes to a high impedance state. If the SHDN pin is left floating, it is recommended to connect a small capacitor of 1 nF between the SHDN pin and the −VS pin to prevent signals from the −IN pin from capacitively coupling to the SHDN pin. 6 +VS Positive Power Supply. Bypass the +VS pin with a capacitance of at least 0.1 μF to a low impedance ground plane, as close to the +VS pin as possible.
Figure 5. Pin Configuration for ADA4097-2 8-Lead SOIC_N and 8-Lead MSOP Table 7. Pin Function Descriptions for ADA4097-2 8-Lead SOIC_N and 8-Lead MSOP Pin No. Mnemonic Description
1 VOUT1 Amplifier Output, Channel 1. 2 −IN1 Inverting Input of the Amplifier, Channel 1. 3 +IN1 Noninverting Input of the Amplifier, Channel 1. 4 −VS Negative Power Supply. In single-supply applications, the −VS pin is normally soldered to a low impedance ground plane. In split-supply applications, bypass the −VS pin with a capacitance of at least 0.1 μF to a low impedance ground plane, as close to the −VS pin as possible. 5 +IN2 Noninverting Input of the Amplifier, Channel 2. 6 −IN2 Inverting Input of the Amplifier, Channel 2. 7 VOUT2 Amplifier Output, Channel 2. 8 +VS Positive Power Supply. Bypass the +VS pin with a capacitance of at least 0.1 μF to a low impedance ground plane, as close to the +VS pin as possible.
analog.com Rev. A | 10 of 31
Document Outline Features Applications General Description Typical Application Circuit Specifications 5 V Supply ±15 V Supply Absolute Maximum Ratings Maximum Power Dissipation Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADA4097-1/ADA4097-2 ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Input Protection Over-The-Top Operation Considerations Output Shutdown Pins (SHDN and SHDNx) Applications Information Large Resistor Gain Operation Recommended Values for Various Gains Noise Distortion Power Dissipation and Thermal Shutdown Circuit Layout Considerations Power Supply Bypassing Grounding ESD Protection when Powered Related Products Typical Applications Outline Dimensions Ordering Guide Evaluation Boards
