Datasheet TIP110, TIP111, TIP112 (NPN); TIP115, TIP116, TIP117 (PNP) (ON Semiconductor) - 7
ManufacturerON Semiconductor
DescriptionPlastic Medium-Power Complementary Silicon Transistors
Pages / Page8 / 7 — TIP110, TIP111, TIP112 (NPN); TIP115, TIP116, TIP117 (PNP). NPN. PNP. …
File Format / SizePDF / 157 Kb
TIP110, TIP111, TIP112 (NPN); TIP115, TIP116, TIP117 (PNP). NPN. PNP. TIP110, 111, 112. TIP115, 116, 117
TIP110, TIP111, TIP112 (NPN); TIP115, TIP116, TIP117 (PNP) NPN PNP TIP110, 111, 112 TIP115, 116, 117
+0.8 +0.8 C) ° *APPLIES FOR I C) C/IB ≤ hFE/3 ° *APPLIES FOR IC/IB ≤ hFE/3 0 0 -0.8 -0.8 25°C to 150°C -1.6 25°C to 150°C -1.6 *qVC for VCE(sat) *q -2.4 VC for VCE(sat) -2.4 -55°C to 25°C -55°C to 25°C TURE COEFFICIENTS (mV/ TURE COEFFICIENTS (mV/ -3.2 25°C to 150°C -3.2 25°C to 150°C qVC for VBE q -55°C to 25°C -4.0 -55°C to 25°C -4.0 VC for VBE , TEMPERA , TEMPERA Vθ Vθ -4.8 -4.8 0.04 0.06 0.1 0.2 0.4 0.6 1.0 2.0 4.0 0.04 0.06 0.1 0.2 0.4 0.6 1.0 2.0 4.0 IC, COLLECTOR CURRENT (AMP) IC, COLLECTOR CURRENT (AMP)
Figure 12. Temperature Coefficients
105 105 REVERSE FORWARD REVERSE FORWARD 104 μ 104 μ (A) (A) 103 103 V V CE = 30 V CE = 30 V 102 102 OR CURRENT T OR CURRENT J = 150°C TJ = 150°C 101 101 , COLLECT 100 , COLLECT °C I C 100 100°C I C 100 25°C 25°C 10-1 10-1 -0.6 -0.4 -0.2 0 +0.2 +0.4 +0.6 +0.8 +1.0 +1.2 +1.4 -0.6 -0.4 -0.2 0 +0.2 +0.4 +0.6 +0.8 +1.0 +1.2 +1.4 VBE, BASE‐EMITTER VOLTAGE (VOLTS) VBE, BASE‐EMITTER VOLTAGE (VOLTS)
Figure 13. Collector Cut-Off Region TEST CIRCUIT VOLTAGE AND CURRENT WAVEFORMS
tw ≈ 3.5 ms (SEE NOTE A) VCE MONITOR 0 V INPUT VOLTAGE MJE254 100 mH -5 V R INPUT BB1 TUT 100 ms 2kW + V 0.71 A CC = 20 V 50 COLLECTOR W - R I BB2 C CURRENT 50 W 100 W MONITOR 0 V RS = V V BB1 = 10 V + CER V 0.1 W BB2 = 0 - COLLECTOR VOLTAGE 20 V VCE(sat) Note A: Input pulse width is increased until ICM = 0.71 A, NPN test shown; for PNP test reverse all polarity and use MJE224 driver.
Figure 14. Inductive Load Switching www.onsemi.com 7
