Datasheet ULR (TT Electronics) - 2
ManufacturerTT Electronics
DescriptionMetal Element Current Sense Resistor
Pages / Page6 / 2 — Metal Element Current Sense Resistor. ULR Series. Physical Data. Metal …
Metal Element Current Sense Resistor. ULR Series. Physical Data. Metal Eleme. Cur. t Sense Resistor. Size. Coating. Values. T (±0.2)
Metal Element Current Sense Resistor ULR Series Physical Data Metal Eleme Cur t Sense Resistor Size Coating Values T (±0.2)
U U L L R R 2 G 5 3 2 / / Non ULR UL U G R 32 / No e n 2 3 0.5, 0.75 100 2 6.5, 7, 8, 9, 10 200 1, 1.5, 2, 2.5, 3 50 U U L L R R G 3125 / e 2 Green 3 0.5, 0.75 1 0 200 0 1 . , 5 ,1 . 0 5 . , 7 2 5, 2 1, . 5 1 ,. 3 5, 2 50 ULR1 25 2.5 4, 4.5, 5, 6 0.5, 0 2 .7 5 5 , 3 1 , 3 1 . 5 5, 2 5 1 0 1, 5 -55 to +170 ULRB2 /
Physical Data
1 50 ULRG3 / Non UL UR L ULB RR213 / Black 1 4, 2 4..5 5,, 3 5,, 3 5..5 5, 10 1500
Metal Eleme
e 2
nt
Metal Element 3 0.5, 0.75 10 200 4, 1 4, .56 1. , 556, ,. 25 5,, . 5 7 2. , 51, 03 10 75 0 50 Dimensions(mm) and weight (mg) Metal Element UL U R L 1 R 1 Black ULRB2 / 0.5, 60,. 6 7 .55, 17, 1.5, 2 75 50 UL
Cur
UUR
r
CurLLB rR R 2
e
B 2/
n t Sense Resistor
ent Sense Resistor
L
2 0.5, 02.755, 31, 31..55, 2 5 1 0 50
Size Coating Values
21
W
0.5 4, 4
T (±0.2)
0..7 5, 5 , 5 ,1 , 5 .1 5.,5 , 1 2 0
D
5 1 00
Wt (nom)
CurUrLR L 2 R1 Black
(±0.25)
ent Sense Resistor
ULR Series
ULR Series Metal Element 6, 6.5, 7 75
Notes:
1. For higher resist0.2, 0.25 ance values please refer to LRMA series. 2. Package sizes 1 1.5 ±0.25 ULR Series 206 and 2010 are uncoated on the top surface and unmarked. ULRB2 / 1.6 ±0.3 1.0 25
Notes
Cur
U r1. For higher resist LR2 2 0.5, 0.75, 1, 1.5, 2 50 0.3, 0.4 ance values please ent Sense Resistor refer to LRMA series. 2. Package sizes 11.4 ±0.25 206 and 2010 are uncoated on the top surface and unmarked. 0.5, 0.6 1.35 ±0.25 ULR Series
Notes:
1. For higher resistance values please refer to LRMA series. 2. Package sizes 1206 and 2010 are uncoated on the top surface and unmarked. 0.75 1.23 ±0.25 1206
Physical Data Physical Data
3.2 1, 1.2, 3.5, 4,
1.6 ±0.1 0.6 1.1 ±0.25 20 Dimensions(mm) and weight 5, 5.5, 6 (mg) Di
Size
mension
Coating
s (mm) and weight (mg) 2, 2.5, 3, 10
Values L (±0.25) W T (±0.2) Physical Data
0.6 ±0.25
D Wt (nom)
Di
S
m
Pz
e
h
n
y
si
s
o
Ci
ns
o c a
ta
m
inl
m
g
D
a
a
n
t
d
a
w 0.2, 0.25 eig
V
h
a
t
u
m
e
g
s
1.5 ±0.25
D Wt (nom) Size Coating
0.5, 7, 8, 9 0.3 1.6 ±0.3 1.0
V
0.
a
6
u
1
e
s
4, 5, 6
0.9 ±0.25 1.4 ±0.25 25 1.1
D
±0.25
Wt (nom)
0.4 1.4 ±0.25 12 Di 1206 06 mensions (mm) a 0 n .d5 , w0 e 0.2 .2i6, g , 3 h 1, t ,( 140 m, g5 ) , 6 3.2 3.20 1.6 2.34 ±0.25 10.16 ±0.25 20 0.5, 0.6, 1 ,4, 5, 6 ±0.1 1.1 ±0.25 12
Si
0
z
6
e Coating
0.25 2, 3, 10 2,7
V
,3
al
,8
u
1
e
0 9
s L
3
2
0
0 1.6
.2
1.6 ±0.1
5) W
0.6 ±0.1
T (±0.2)
2.24 ±0.25 0.6 ±0.25 0.69 ±0
D
.25 20
Wt
2
0
nom)
None 0.50, .07, 8, 9 7 5. , 6 8 1, 1 9 4, 45, 5, 6 2.54 ±0.3 1.0 0.9 ±0.25 0 1.. 1 9 8. 4 1 ± 0 ± .02.5 2 50 1206 0.3 0.2 2, 3, 10 3.20 1.6 2.04 ±0.25 2.34 ±0.25 None 0.5 2, 1 6, 4 7, 5 8 1.85 0. 4 6 ±0.25 20 2010 5 ±0.1 20.4 0.25 5.08 2.54 2.24 ±0.25 40 7, 8, 9 2.54 ±0.3 1.0 , 6, 37, 8 ±0.15 1.84 ±0.25 0.9 ±0.25 50 0.3 2.04 ±0.25 2010 5.08 2.54 1.504 ±0.25 40 N Green one 0. 0.5 5 0.4 9,, 3 1 1,0 4, 5 ±0.15 0.6 2.17 ±0.25 1.84 ±0.25 1. 1 02.49 8 4± 0 ± .02.5 25 20102010 Underside 0.5, 1, 4, 5 2, 6, 7, 8 5.08 5.08 1.84 ±0.25 2010 1.54 ±0.25 0.75 9, 0 1 . 0 5 5.08 2.54 0.6 12.2698 ±0.25 40 2, 6, 7, 8 3 ±0.15 2.04 ±0.25 1.54 ±0.25 1.04 ±0.25 Green 0 0..5 7 2.54 ±0.15 0.6 2.648 ±0.25 40 1, 1.5, 4, 5, 5.5 3 9, 10 0.6 1.84 ±0.25 1.04 ±0.25 1.29 ±0.25 Underside 9,1 0 0 1, . 7 5 5 Green , 6 2.54 ±0.153.0 0.6 1.29 ±0.25 21.4983 ±0.25 40 2, 2.5, 6, 7, 8 1. 0.5 2.68 ±0.25 0.15 15, 56,. 6 5, 7 3 ± .00. 2 1.54 ±0.25 2.98 ±0.25 Green 1.943 ±0.25 1 2 .– 0.75 2.48 ±0.25 30.2 2.88 ±0.25 5, 3 6 , .5 8 ,- 7 22 3.0 ±0.3±0.2 1.0 1.04 ±0.25 1.4138 ±0.25 0.25, 0.3 1, 5, 6 3.0 2.68 ±0.25 Green 2 – 3 4,, 8 4. -5 22 12. 1 1.8 9 3± 0 ± .02.5 25 9, 10 0.4 1.5, 6.5, 7 ±0.2 1.29 ±0.25 2.18 ±0.25 1.43 ±0.25 0.5 - 0.75 4, 04..55 1.0 1.4 2.18 ±0.25 2 0.15 – 3, 8 - 22 3.18 ±0.35 2.98 ±0.25 1.93 ±0.75 1.18 ±0.25 1 - 10 0.6 0. 0 7 . 5 5 , 2.5 1.40 4, 4.5 2.18 ±0.25 00.2 0.5 1.4 .75,1 2.5 10.08 2.88 ±0.25 0.75, 2.5 2512 0.5 6.3 3.0 ±0.3 5 1.0 1.0 1.4 60 0.711 1.55, 2.5 0.8 25 0 0.. 1 8 6.5 2512 0.25, 0.3 12 6.35 0 2.68 ±0.25 6.35 60 60 1.5 0.65 2 1 , .5 5, 1 6 0.06. 0 5 5 2512 0.4 8 2, 5, 6 6.35 0.5 2.18 ±0.25 2, 53 1. ,56 3.18 0.5 60 Black 7 65 1.3 ±0.38 3 0.7 1.3 ±0.38 Black 0.5 3.18 ±0.25 2.68 ±0.25 23.5 , 3 3 .5 5, 6 3 ± .01.8 2 5 0.71 Black 0 0.. 0 7 7.1 5 1.3 ±0.38 Metal Strip Cur 0.754 Black r 3.5 43 ±0 3 .2 1 5 8 0.6 0.07. 0 1 67 2.48 ±0.25 ent Sense Resistors Surface Mount 1.3 ±0.38 4.5 0.58 1, 5, 5.5, 6 Metal Strip Curr 4 4. 3 5 . ±0.25 0 0..6 ent Sense Resistors Surface Mount 58 71 5.5, 6.5 0.47 1.93 ±0.25 Metal Strip Cur5r. 45.,5 6 4 .5 0.54 0. 87 6 ent Sense Resistors Surface Mount 2, 2.5, 3, 3.5, 7 3.0 ±0.2 0.6 0.45 5. 10 5,4 7.65.5 0.8 0. 0 4 . 75 58 1.18 ±0.25 8, 9, 10 1.9 ±0.15 5.5, 6.5 0.47
Welwyn Components
ULR Series 7 10 0.04.5 8 1.9 ±0.15 7 0.45
Welwyn Components
ULR Series 4, 4.5 10 0.8 2.18 ±0.25 1.9 ±0.15
Welwyn Components
ULR Series 1.5, 6.5, 7, 7.5 10 0.8 1.43 ±0.25
Construction
1.9 ±0.15 2512
Construction Construction
0.5 6.35 1.4 60
C B o lan c s k tr c u o c at tion Construction Construction
0.75, 2.5 1.0
B
A
lac
o
k
w
c
T
o
C
at
R resistance
Black Coat
1 al oy plate, with tin plated conn 0.8 ection bands is protectively coated on the upper and lower f Aa low Ace los T wa C n R T d re C n R u si m s reseta i ri n st c c aanl e lcy al e m oy p alarkela loy d te pl w , at iet w ,h itth wh it etin h re p tinsila s pl tte a d at n e cc d eon c v n o a n l e u c n et e .io c Tn ti h o ib n san bp d aa nrst d i s s p i s r s uo p irt te a c otbel tiev cti feoly v r c el w o y a a c v te o e d at o e r o d n roetfh n l e t o u h w p e s p u o p ledr p ea er rind n ang l d. ower 1.5 0.65 lower faces and numerical y marked with the resistance value. This part is suitable for wave or reflow soldering.
G
f
r
a
ee
ce
n
s
c
a
o
n
a
d
t
numerical2, 5, 6 ly marked with the resistance val 0.5 ue. This part is suitable for wave or reflow soldering.
G
A
re
e
o
n
w
co
T
a
C
t
R resistanc 3e al oy plate is grooved to 0.7 set the fi 1.3 ±0.38 nal resistance, the lower faces are tin plated for Black
Green Underside Coat
3.18 ±0.25 A lo con w nec T ti C o R ns, re a s n idsita t ins 3.5 ce p al oy rotectiv p el a y te co iaste g d ro o o n vte h d e t u o pp 0.71 s e e r ta tnhdelo fin w a e l r f r a es ceis s ta a n n c d e, nu th m eri low cal e y rmface arkesd a wre ith tin he pl reastie s d ta f n o c re con va A ll nuoee.wctTiTohiCnss R ,pr aaenrtsidisstita iOnsNcpL e rotectiv Yal slu o iytapl eblaltyeefcoiosa r gte ref rodloo owvnesdth olt e doeur s ipnetpgte.hre afnid nallorweesir stfaace nc se aanndd ntu h m e l eoriwca er lfya m cearke onl d y i wsith pr tohte ectre e sdist wiatnhce an 4 0.6 va e lpuoex.y Th coisatipnagr.t is Th O e NloLY wersufiata c b e lseafroer tirenflpolw at s e o d lfdoerricng on.nections. This part is ONLY suitable for reflow soldering. 4.5 0.58
Uncoated Marking
5.5, 6.5 0.47
U
A
n
c
o
o
w
at
T
ed
CR resistance al oy plate is grooved to set the final resistance and the lower face only is protected with an AOnly black coated parts are marked. For values which are integer numbers of mil iohms, the marking is 4-character e l p ow xy TC co R ati re n s g. is Tta h n e cle 7 o a w l erofya p c leaste aris e tgiro n o pl vae t d e to f s r e c t t 0.45 onhne fcitna o ln r s e . s T is hita s npcaert ain s d O th N e LYlosw uietra fba l ce e fo o r nrly eflis o p w ro s t oledcete ri d ngw . ith an eIp Eox C y62cocaotdine;g.e T.gh.e“ lRo002” for 2m , “R010” for 10m . For values including fractions of a mil iohm the marking is 3 or 10 wer faces are tin plated for con 0.8 nections. 1.9 ±0.15 This part is ONLY suitable for reflow soldering.
Markin
4-char
g
acter code using “M” to indicate the decimal point, e.g. “M75” for 0.75m , “1M50” for 1.5m .
Markin
Only 2
g
512 size parts are marked. For values which are integer numbers of mil iohms, the marking is 4-character O I n E ly C6 2 2 5c1o2d s e;ize e.gp.a“rt Rs0 a 0 re 2” f m or ar 2 ke m d., F “ o R r 01v0a”lu f e ors1w 0 hi m ch. a F re or ivnatleugeesri n n u cl m u b di e n rgsf of racmi tiolnio s hm of s a , th mileli m oh ar m ktin h g e is ma 4 r - kicnha g ira s c3teor IE 4- C c 6 h 2 ar c a o ctdeer;ceo.g d .e “R us0 i 0 n 2 g ” fo “M r ” t 2 o m ind ,ic“R at 0 e 1t0 h ”e fo d r e 1 ci 0 mm al p.oFio nt r, v e a . lgu . e “ s M i7n5cl ” u f d orin0g.7fra 5 c m tio,n“s 1 o M f5 a 0” m foilr io 1.h5m m th.e marking is 3 or 4-character code using “M” to indicate the decimal point, e.g. “M75” for 0.75m , “1M50” for 1.5m . General Note
Sn
BI Technologies IRC Welwyn
Sn Pl P a l t a e t d e Fi F ni n s i h s
TT Electronics reserves the right to make changes in product specification without notice or liability.
Sn Plated Finish
All information is
B
subject t
l B
o
a
T
c a
T
k c
Electronics’ own data and is considered accurate at time of
G
g
r G e r
oing
e e
to
n e C
prin
o C
t.
a o t a & Un U c n o c a o t a e t d e Black Green Coat & Uncoated
www.ttelectronics.com/resistors
T
© T
e T r e m r i m n
T Electr
a n t a iton o D
onics plc
e D t e a t i a ls: s Ter Ma m te t irna al a tion Details:
Matt tin plated finish over a barrier Matt tin plated finish over copper. layer 10.22
Ma So S tle d ri e a r lab a i b lity t
M 9 a 5 tt % t % in mi m p n lat coev co de frin a i g seh( o MvI M e L r- a ST S bar D r 2 ie 0 r 2 l F a/ye 2 r 08 0 H 8 , H 23 2 5 3 º 5 C º 2 se s cs e ) cs
Solderability
95% min coverage (MIL-STD 202F / 208H, 235ºC 2 secs)
General Note AE A Gene C Er - C Q - al No 2 Qte0 General Note 200 Table 7 Max
BI
(add R0005) Technologies IRC Welwyn TT electronics r
0 Table 7
Max.
(add R0005)
General Note A rr E ef e .f.C
TT electr
-Q
onics
2
r
00 Table 7
Method
All information is subject to TT electronics’ own data and is consider All information is sub
Test Method
ject to TT Electronics’ own data and is considered accurat ed accurate at time of going to print.
M
Bl Bal
a
c ac
x
k k
&& (add R0005) TT electronics reserves the right to make changes in p All information is subject to TT electr roduct specification without notice or liabilit onics’ own data and is consider y. Green
ref. Test Method
ed accurate at time of going to print. e at time of going to print. wwwu wwu.bitechnologies.com ww n w c n o c a o taetd e d Green w .bitechnologies.com ww .i w r.ictt.com ww rwww.tt w ctt.com ww .welwyn-tt.com w.welwyn-tt.com All information is subject to TT electronics’ own data and is considered accurate at time of going to print. electronics.com/resistors
© TT elect
3
ronics plc
Hig
T
h
e
T
s
e
t
Black & mp. Exposure * MIL-STD-202 Method 108 wwwu.bitechnologies.com ww ncoa 1 t ed Green 1 w.irctt.com www.welwyn-tt.com
© TT elect
3
ronics plc
© TT Electronics plc High Temp. Exposure * MIL-STD-202 Method 108 1 1 4 Temperature Cycling JESD22 Method JA-104 0.5 0.5
© TT elect
34
ronics plc
High T e Te m m p p. era tExp ure o Csyucrle i n *g MI J L-S ES T D D-202 22 Met Me hodt hJod A 1 -1 0 0 8 4 1 0. 5 1 0. 5 03.14 03.14 06.17 46 6 Te M Mm oi oi pssera tur tur teeure R e Re C sisi y st stcaalinnc n ge c e J M MES IL- IL- D SS 2 TT 2 Met D-202 D-202hod M e M teJhtAo ho-1 d d 011400 6 6 0.5 1 1 0.5 1 1 03.14 6 7 Moistur Bi e as R e e d si H suta m nic di et y MI M L- I S L- T S D-202 T D-202 M e M tehto h d o d1 0 1 6 0 3 1 1 1 1
